  New Posts New Posts RSS Feed - Electrical topic
Electrical topic
1976kjell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1976kjell Quote  Post ReplyReply Direct Link To This Post Topic: Electrical topic
    Posted: 23-August-2020 at 9:14AM
Hello
I have some question about the electrical system in 1976 Torino Wagon
I have googled, but didnt find any general info about which bulbs to use in those cars. The tail-/flash-/headlights are ok, 21w and 21w/5w, but the sidemarkers was new and "modern" for me
Is it ok to use w5w-bulbs in the sidemarkersockets like this: https://bit.ly/3hnob87
Also the taillightassemblys fastenings-"nuts" by plastic are needed. Is there any shop that sells these like the one on this photo, and the related screws? https://photos.app.goo.gl/qoqBufcKB8gQj3Bo9
Link had to be used so far, until my membership is upgraded to "new member"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2020 at 12:22PM
I am not sure if that bulb you linked to is correct.  It appears correct, but I don't know if the specifications are the same as a US bulb.  The side markers use a 194 bulb, which is once like this:
Compare the specs to the European variant, and if it is the same it should work.  Or just order them from RockAuto.
As for the nylon nuts, I don't know of a source off hand.  There ware similar ones in my grille I was still able to source from a Ford dealer several years ago.
Gazoo2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gazoo2 Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2021 at 5:30PM
The w5w has the same size base as a 194, but the w5w is brighter and runs hotter.  It was causing heat damage to the socket in my European car so I changed to 194s to prevent damage.  The 194s are bright enough.
72 GranTorino "rat wagon" 351C, a work in progress
69 Mustang Mach 1, 351w, Borg Warner T5, rack & pinion steering, fuel injected
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2021 at 6:45PM
look for the 194LL (Long Life)
This page was generated in 0.112 seconds.
