  New Posts New Posts RSS Feed - Mystery 460
Mystery 460
NoNameTag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NoNameTag Quote  Post ReplyReply Direct Link To This Post Topic: Mystery 460
    Posted: 24-August-2020 at 7:07AM
brand new to restoration. 72 GTS I found has a 460 plopped into it. The #s on the heads say “D3VE-a2a.” From what I’ve been able to find out that means they were made in the early 70s for a Lincoln. Other than that I have no idea where it can from or when it was made. I’m thinking since I’ve never rebuilt an engine knowing where it came from might help me figure out what I need to do to it. Any help in figuring out where it might have come from would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2020 at 1:03PM
Do you have the block casting number too? Is there a partial VIN anywhere?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2020 at 1:43PM
Also look at intake and exhaust manifolds for part numbers may narrow down the possibilities. D3 heads were used from late '72 into the early 80's.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2020 at 4:14PM
not necessarily from a Lincoln, just means the Lincoln division paid the development $
Post Options Post Options   Thanks (1) Thanks(1)   Quote NoNameTag Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2020 at 7:31PM
Haven’t found it yet. Supposed to be on the driver side on the block itself right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NoNameTag Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2020 at 7:32PM
I had the intake # but apparently didn’t write it down. I’ll have to look at it again when I get back home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-August-2020 at 3:48AM
Older 460 parts are better than the newer late 80's models etc. The heads and intakes never got better after the 70's, they actually went backwards. The emissions etc, for those late 460 trucks, they ruined the potential and Ford put no more development into the engine.
This page was generated in 0.201 seconds.
