  New Posts New Posts RSS Feed - No power on accessory
piper62j View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Topic: No power on accessory
    Posted: 21-April-2021 at 11:24AM
1968 Torino GT.  When turning the ignition key to accessory, the radio will not work... Radio works when turning the ignition key to on... I tested the ignition switch and there is continuity to the accessory terminal when activated but no power to the radio when the harness is plugged in.
Any ideas anyone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2021 at 11:59AM
fusible link at the solenoid blown?
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 12:34AM
There is accessory power with the ignition key on, so I believe the fusible link is ok.. There is no accessory power with the key turned left to accessory..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 4:34AM
Do you have a wiring diagram for your car?  It might come down to tracing the circuit.  Do all other things that receive power on accessory mode get power ok?
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 4:05PM
Yes.. All other items on the accessory circuit receive power when turning the key to the right, or "on".
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 11:54PM
I would guess the ignition switch is bad, did it occur all at once or intermittently?
There were some defective factory ignition switches in the late 80's. One example is all the 84-89 Mark VII's should have those replaced. One evidence of those going bad was the two halves of the ignition switch coming apart, a gap showing. That's a critical part of every car, I wouldn't hesitate to replace that at its age.
This page was generated in 0.055 seconds.
