  New Posts New Posts RSS Feed - 71 Ranchero Hood Scoop Recommendation
Jordanbrown123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordanbrown123 Quote  Post ReplyReply Direct Link To This Post Topic: 71 Ranchero Hood Scoop Recommendation
    Posted: 27-May-2021 at 10:16AM
Looking to put a scoop on this thing. I tried twice to make my own out of sheet steel, but was never happy with it. I'd like to be able to drive the thing worry free in the rain or just be able to park it outside in the rain. Anyone know of some scoop styles that will look good? Preferably bolt on or bond on scoops.
71 Ranchero, 351w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordanbrown123 Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 10:17AM
Oops, didn't realize those were sideways...
71 Ranchero, 351w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 10:40AM
Are there any reproductions of the late 60's hood scoops? Those were great looking and many could cover that hole size you have there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 10:45AM
looks like you're wanting one for filter clearance? and some style but no water getting in???? if you have any yards near by with older cars i'd suggest a factory bolt on scoop from a 79 mustang?
1979-1982 MUSTANG CAPRI GT COBRA HOOD SCOOP SHOW QUALITY
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordanbrown123 Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 5:20PM
Alright thanks, ill check em out
71 Ranchero, 351w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordanbrown123 Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 6:42PM
Definitely lookin for a Mach 1 style scoop I'm thinkin. Just need to find one that's large enough
71 Ranchero, 351w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 7:43PM
those factory scoops like i posted a pic of are about 24" x 25" and like 1 1/2- 2" tall
 IIRC they were on 79-82 mustangs i used to see them alot at yards and swapmeets years ago...
 if you can't find an original there is a guy in canada that makes handlaid reproductions of those ...
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2021 at 12:26AM
Maybe a 69-70 Boss 429 or Cougar Eliminator scoop?  They're available aftermarket.
I think the Mach 1 scoop might be a little small.
Like John mentioned, maybe the 79-82 Mustang scoop.  Maybe available aftermarket?  There was a scoop exclusive to 83 Mustang GTs, but they're hard to find.  It faced backwards, like a cowl induction scoop.  But, could probably be turned either direction.
Or, keep an eye out for a 70-71 Torino GT hood.
Jeff
72 base Torino (modified)
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordanbrown123 Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2021 at 10:26AM
https://www.summitracing.com/parts/sum-wl20467
Perhaps this one will work. Has the right dimensions
71 Ranchero, 351w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordanbrown123 Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2021 at 11:25AM
I am worried however, the ridges in the hood may cause some headache when putting this on...
71 Ranchero, 351w.
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2021 at 10:30PM
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-June-2021 at 2:25PM
i think the angular nose of the 71 would lend itself well to the 72 GT frankenhood treatment,
it would look like a stock 71 hood on steroids
This page was generated in 0.104 seconds.
