  New Posts New Posts RSS Feed - Hooker headers 6915hkr
73torino gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Topic: Hooker headers 6915hkr
    Posted: 30-August-2016 at 2:02AM
Opinion on the hooker headers 6915hkr, I have a 73 gts 351c with a c6 tranny will these fit. Everything I've read tells me yes.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2016 at 2:13AM
Those are for 71 to 73 mustangs, i doubt that they will fit. Hooker stopped making the correct headers a few years ago, but you might be able to find a used set for $350.00 to $400.00.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2016 at 2:14AM
There is a set for sale, but the price is $727.54 plus shipping. If you want to see them Click here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2016 at 2:17AM
If you want to see a business that makes headers for your car Click here.
If you want to contact them Click here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2016 at 2:20AM
The ceramic coated headers are the most expensive option at approximately $950.00. There is also the option of buying them "painted" or "bare/unpainted" for a lower price. The price might start at approximately $730.00 for bare/unpainted or painted .
Edited by dave302 - 30-August-2016 at 2:23AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2016 at 11:35AM
Ouch!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2016 at 11:38AM
What's the issue with the 6915 ones,according to the specs they should fit
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Posted: 30-August-2016 at 11:55AM
So r there any out there for 300$ or less or the factory 4v exhaust manifold?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 9:00AM
So will Windsor 4v exhaust manifold work on a Cleveland?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 9:08AM
No, it will not work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 9:09AM
Different bolt pattern I believe
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 9:11AM
Damn it why can't anything ever be easy....I can't afford the ones in the link so I might have to just buy some headers and make them fit.
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 4:26PM
extrudehone the 4v exhaust manifolds and call it a day, cheaper and less headaches IMO
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 5:54PM
this just popped up in another thread: (read the 3rd post)
 http://forum.grantorinosport.org/best-headers-for-a-351-2v_topic15419.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 9:58PM
Those will not fit with a C6 transmission and they are for 2V heads. Unless you can find a way to fabricate custom exhaust manifold/header gaskets they might not seal properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 10:05PM
They will fit with a C6 transmission, but they might not fit properly into your car. I also heard another member say that they will not fit correctly into the car. If you want to contact him  Click here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 11:05PM
If you are looking for 351c 4v exhaust manifolds, the 1970 through 1974 passenger side are all the same. But only the drivers side from a 1972-1974 torino, gran torino, montego or ranchero, 1971-1973 mustang and 1971-1974 cougar will fit.
The drivers side from a 1970 mustang and cougar and 1970 and 1971 torino will not fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 11:11PM
There is a pic below of a driver side 1970 mustang/cougar and 70-71 torino/ranchero/montego exhaust manifold, notice how the exit end points up (arrow). If you try to install one of these in your car it will touch your steering box/gear.
Edited by dave302 - 31-August-2016 at 11:47PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 11:16PM
There is a pic below of a driver side manifold from a 1972-1974 torino/montego/ranchero, 1971-1973 mustang and 1971-1974 cougar. Notice how the exit points down (arrow). These will not touch your steering box/gear.
Edited by dave302 - 31-August-2016 at 11:26PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2016 at 11:22PM
There are also the exhaust manifolds from the 1971 boss 351C 4v engines. The exhaust exit points down on the drivers side, but the driver and passenger side have a larger two and a quarter inch exhaust exit on them and they might be too big to fit on your existing exhaust down pipes. You might have to take the car to an exhaust $hop to make them fit correctly.
Edited by dave302 - 31-August-2016 at 11:46PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2016 at 1:22AM
Thanks for the info Dave been very helpful. In the pic of the driver side exhaust did u mean passenger side as u can see the ports?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2016 at 1:30AM
Your welcome.
No, i meant the drivers side. I do not know the reason for that picture being backwards. That is actually a drivers side manifold.
Edited by dave302 - 01-September-2016 at 1:58AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2016 at 1:33AM
Just checking, so are the fmx and the c6 bell housing pretty much the same size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2016 at 1:37AM
Yes the bellhousing on your c6 is pretty much the same size as a small block fmx bellhousing. But the c6 transmission is wider, that is the reason that some of those other headers will not work.
Edited by dave302 - 01-September-2016 at 2:51AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2016 at 1:40AM
Here is another pic of the driver side manifold.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2016 at 1:44AM
The fmx actually has a removable bellhousing, but the bellhousing in the third post in the thread below is a small block fmx bellhousing.
Edited by dave302 - 01-September-2016 at 2:53AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2016 at 1:48AM
Thanks again Dave,having a list of what will and won't work should really help my search as I would rather have stock manifolds on installing of headers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 01-September-2016 at 1:50AM
Your welcome.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 22-September-2016 at 10:15AM
FPA headers had been making headers for Hooker from my understanding.
After seeing the quality of FPA {Ford Powertain Applications} I will be going that route when I rebuild my 351c CJ 4v.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73torino gt Quote  Post ReplyReply Direct Link To This Post Posted: 22-September-2016 at 11:05AM
I got a set of 4v manifold off ebay, so we're all good thanks for the info folks
This page was generated in 0.072 seconds.
