  New Posts New Posts RSS Feed - Laser stripe part numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Topic: Laser stripe part numbers
    Posted: 22-January-2022 at 1:59PM
Ok, I’ve gone through everything I can..... no answers—
So, is there a list of PART NUMBERS, not codes, for laser stripes? I have a complete NOS ‘73 set. I BELIEVE it’s supposed to be a blue set, but I’m not about to peel any paper off just to look. I’m not going to need a blue set, but might be interested in trading for a set that would go on a red car......
I just want to verify color by the part numbers.
Dfox
Edited by hogfiddles - 22-January-2022 at 2:28PM
pete rad View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 24-January-2022 at 2:31AM
The part numbers for the stripe kit is always D3OZ-6520000. Depending what color the kit has there is always an A, B, C or D at the end of the part number. I am not 100% sure but i believe the part numbers are:
D3OZ 6520000-A - light gray to dark blue
D3OZ 6520000-B - yellow to Brown
D3OZ 6520000-C - yellow to Red
D3OZ 6520000-D - light Green to dark green
I am 100% sure that the D3OZ 6520000-B is yellow to brown.
  Brown - Yellow to Brown
Edited by pete rad - 24-January-2022 at 4:07AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 24-January-2022 at 4:18AM
hmmm my number is much more involved.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 24-January-2022 at 7:30AM
I have never seen that part number before. Is that a ford stripe kit box or is an aftermarket stripe kit box? The D3OB means it's for a '73 torino or gran torino.
I can only see the first 13 letters and numbers in the part number, which is D3OB-65208A09A, what are the last three numbers or letters of the part number? It appears that someone stamped the part number upside down on the instructions section of the box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 24-January-2022 at 10:38AM
that’s actually right on the stripe.... I’ll see if any others are clearer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 24-January-2022 at 2:23PM
could this number on the stripe itself be a Ford 'engineering' number rather than an actual part number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 24-January-2022 at 3:03PM
Yes most likely. That is usual to have different numbers on the actual part, than the official part number. I learned that in the late 70's, but I didn't understand the explanation my part guy told me then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2022 at 3:30AM
I think the other guys are probably right, it's an engineering number.  I don't know how these numbers translate to the parts number, I'd "guess" it's blue, because it has the "A" in the first portion of the number D3OB-65208"A" but I could be wrong.  I checked my parts catalog and it had no other new information either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2022 at 11:40AM
Phoenix might know the OEM part numbers
This page was generated in 0.123 seconds.
