Transmission line size |
| Author | |
pyntre
Joined: 29-March-2007 Location: United States Status: Offline Points: 275 |
Topic: Transmission line sizePosted: 08-February-2022 at 10:38AM |
Hi ,
Can someone confirm the cooler line size on an Fmx trans . Thinking they are both 5/16 “ Thanks
1975 Montego
Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 3443 |
Posted: 08-February-2022 at 2:42PM |
Most older Fords had 5/16" lines, but 3/8" lines are much better. Ford learned and upgraded all trans lines sometime in the 1980's, the smaller lines restrict flow a little too much. I'd put 3/8" on anything, and the parts stores carry a variety of lengths with the fittings on each end. It's listed as fuel line, and they used to have it on display racks.
pyntre
Posted: 08-February-2022 at 3:12PM |
thank you for the response and information!!! 👍
Posted: 13-February-2022 at 12:25PM |
what good does upsizing the tubing if the internal orifice of the fittings is more like 1/4" ? |
Posted: 13-February-2022 at 2:20PM |
The orifice isn't always the same size for all fittings. The main fittings on the side of the transmissions differ for a 5/16" line versus the 3/8" line, not much but slightly. The late late model transmissions require even more flow than the prior 3/8" lines and simple coolers. Those have to have noticeably bigger coolers, and the parts they use have less restrictions in the whole system. I read a little of that this past Fall when I was researching the 6R80 six speed. The notes warn of using lesser coolers or fittings etc, but that is a different trans of course. I think just keeping good flow in general is wise, so avoid smaller parts etc, for the trans cooling system. It cannot hurt.
Posted: 14-February-2022 at 7:36AM |
5/16" is standard across most cars... yes the internal fittings can be 1/4" so bigger tubing wont increase any flow....
pyntre
Posted: 14-February-2022 at 7:55AM |
This is not a performance build , but will be adding an external cooler to the system . I want to get the transmission system done and forget about it . Thanks for the info everyone!!
All restrictions are restrictions. Small 5/16" line flows less than 3/8", regardless of the fitting orifice sizing. It's the same as an exhaust, just because the joint at the collector is less than 2 1/8" in size, that does not mean that 2 1/8" pipe is sufficient for the whole system. You should make everything flow as much as possible, within reason. 3/8" lines are much better than 5/16" lines, always. That's like being cheap building a house with lesser materials, hell 7/16" roofing OSB is good enough, why not. The next size thicker will last decades and not warp, but it'll cost an extra $500, let's be cheap with building that $200k house.
pyntre
Posted: 14-February-2022 at 11:43AM |
going to run -6 lines to everything, that’s 3/8”
Should be fine for this ditch runner !
