  New Posts New Posts RSS Feed - Water pump backing plate 351c?
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: Water pump backing plate 351c?
    Posted: 21-August-2022 at 4:38AM
Hello forum. I took the water pump of the 351c engine today. There was no backing plate…is this normal? The pump had just a gasket and then sat on the engine timing cover plate.
I forgot my phone, so I couldnt snap a photo..will do tomorrow.
Thanks…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2022 at 6:36AM
I guess there is none….just the timing cover. I have cleaned the pump and plate up nicely. The pump is still the original Ford. 71 dated. No play in the bearing. Still good!
Yellosn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yellosn Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2022 at 8:32AM
Sounds right. It threw me a bit too since most of my experience was with small chevys. That’s cool about your water pump! 👍
Troy Emerson
Eugene, Oregon
1972 GTS 4speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2022 at 11:59AM
Replace the WP, but save the old one. The seals are the weakest links in the WP if the bearings survive, and somewhere those can be changed. Just as a core I think they are somewhat valuable.
I bought a reverse rotation WP to attempt to make up a serpentine belt system. I haven't begun to hunt the WP pulley that it will take to match a later crank pulley etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2022 at 7:24PM
Yes…you may be right. I will look into it. I will definitely save the old original pump. I didnt have any leaks with that pump mounted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2022 at 9:09AM
I agree, don't use the original.  Mine was also original, I saved it, but upgraded to a flow cooler aluminum pump.  Painted it Ford blue and looks close enough to stock that no one notices.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2022 at 11:36AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2022 at 7:15PM
I bought a GMB 1251110 over at rockauto. I think it is made in Japan…so should be ok…I think.
I tried to find a Motorcraft…..no luck…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2022 at 1:45AM
That GMB is a fairly decent brand I think. The real problem is now there are easily 20 bands for most parts, whereas 35 years ago there were maybe six or less. It used to be easy for most people to figure out which were good parts, and which were likely junk. Now most brands fall into the lower quality category. Dorman is huge now, but they have been a lower level for so long that the sales have grown them world wide into one of the most popular brands.
You have to be careful with all brands, and certain parts should only be used from the OEM, or a rare other high end brand. Many electronics parts fall into that category, and one I learned 30 years ago, the starter relay on the fender. Don't buy any off brand version of those ever.
This page was generated in 0.061 seconds.
