  New Posts New Posts RSS Feed - Would like To Buy
Would like To Buy
hamilton7711 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Topic: Would like To Buy
    Posted: 15-July-2023 at 12:33AM
Very much interested in purchasing a 1972 or 1973 Gran Torino  Sport.. Must be the right color and have an R Code or Q code engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2023 at 6:14PM
What is an R code engine, inline 6? N, Q, S, and H were 72 and up.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2023 at 3:41AM
Maybe that's a 427 SOHC, a Cammer special edition?
MOTORCITYBADBOY View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote MOTORCITYBADBOY Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2023 at 1:44PM
I know most Ford fans probably already know this-
The R-code was reserved to Mustangs 68-72, Cougars 68-70, Torinos and Cyclones 68-70. The 68-70 R-codes were the 428CJ-RamAir, The 71 R-code Mustang was the Boss 351, and the last gasp for the R-code was the 72 351HO, which was a slightly detuned Boss 351.. It was not a separate model like the Boss 351- the 72 R-code engine was available in any body style..
The 69-70 Q-codes were non-ram air 428CJ cars. From late 71-74(I think)- the lower compression Q-code 351CJ replaced the M-code 351-4V Cleveland, which appeared in 1970 Mustangs, Cougars, Torinos, and Montego/Cyclones.
Tom
A soft heart for orphaned cars...
8 Mustangs- 69-2014
4 Ford trucks 69-96-97-03
2 Tbirds- 79-95
1 Gran Torino Sportsroof 1972
1 Cadillac- 1972
1 Harley VROD-2005
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2023 at 2:50PM
That would nice, and super rare. The 351HO was a 1972 engine only, and it had adjustable rockers, so the pedestals were cut down just like the Boss 351 heads. The main changes were the compression and cam, the heads were the key assemblies though. Any closed chamber Cleveland is a big advantage for building power, much easier to get the compression up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2023 at 5:33PM
Was there ever an HO 72 documented?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2023 at 11:13AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2023 at 11:44AM
I get it. I sent out wrong information. My mistake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamilton7711 Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2023 at 11:48AM
Thanks for the information.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2023 at 11:50AM
Check the special dipstick, the R code 351 engines take six quarts but use the identical oil pan as all Cleveland's(not the double sump truck).
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 18-July-2023 at 1:59PM
No R-Code Torinos ever, but there were Mustangs.  There were 398 R-Code engines built in 1972, so even more rare than a '71 R-Code Boss 351.   To reduce the emissions in 1972, Ford lowered the compression to an advertised 9.2:1 (9.0:1 measured).  This was accomplished by switching to open chamber combustion chambers and flattop pistons.  The camshaft was revised to have less duration, 275/275 degrees, but compensated with slightly higher lift of 0.491”/0.491”.  It continued to use the same carburetor and intake, but the carburetor was recalibrated for cleaner emissions.
