Header Gaskets |
| Author | |
Topic: Header GasketsPosted: 27-August-2023 at 12:40PM |
I am looking at replacing my leaking header collector gaskets. I was thinking of using some dead soft aluminum gaskets instead of the paper ones I have. Summit has copper ones for a little cheaper price. Any opinions or experiences to share before I order? I am sure either are better than paper. |
Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 3445 |
Posted: 27-August-2023 at 3:13PM |
The last link of a copper pair looks like the best chance to seal well. I like their appearance, they look fairly thin with a surface shape that might seal well. I hated my first set of 351C headers, the collectors that is. They barely leaked a month or so after install, but the first speed bump I grazed made it worse, and I never could stop the leak. That was 1982 etc, we didn't have the better gasket choices like now. I suggest checking and making the two halves as flat or matching as possible, and add some Ultra Copper to the gasket surfaces as well. Hopefully you have nice mating halves of the collectors, so they do seal okay. I got the Hooker headers a month or so back, I don't know how they are going to fit, but I like the quality in hand. I plan to weld on V-band flanges to seal securely and change it from 3" to 2.5" pipes somewhere nearby.
Posted: 29-August-2023 at 10:39PM |
i have the mr gasket copper ones like that in my vette but no leaks and they've been in there for several years
Joined: 19-December-2011 Location: Summerfield, Fl Status: Offline Points: 2341 |
Posted: 30-August-2023 at 12:30PM |
Vince,
FWIW, I have had great luck using Flatout brand graphite header gaskets, never had any leaks and some of the margins between header port and the head's port are less than 1/8" in places. They are re-usable if need be. Good luck with whatever you choose.
Posted: 01-September-2023 at 3:28PM |
Vince have you considered using only RTV, skip the gaskets?
Posted: 02-September-2023 at 3:24AM |
Thanks for the feedback guys, sound like the cooper should work well. My gaskets are leaking at both the heads and the collectors. Both are just using the hooker paper gaskets. I bought a set of Taylor Aluminum seal-4 good header gaskets for the heads a while ago, just haven't got them installed and now the collectors are leaking too. So I am hoping to get both fixed this fall before I put the car away for winter. It sounds like crap. Rock, no I hadn't really considered RTV. I have heard mixed reviews on those who have used it. The other thing I like about metal gaskets is that they are reusable and cleaner than RTV.
Posted: 02-September-2023 at 3:25AM |
Thanks for the feedback guys, sound like the cooper or the flat out graphite gaskets should work well. My gaskets are leaking at both the heads and the collectors. Both are just using the hooker paper gaskets. I bought a set of Taylor Aluminum seal-4 good header gaskets for the heads a while ago, just haven't got them installed and now the collectors are leaking too. So I am hoping to get both fixed this fall before I put the car away for winter. It sounds like crap. Rock, no I hadn't really considered RTV. I have heard mixed reviews on those who have used it. The other thing I like about metal gaskets is that they are reusable and cleaner than RTV.
Posted: 02-September-2023 at 6:07AM |
wipes with a cloth, trims with a blade and smooths with a finger, i just can't justify the $ for the fancy gaskets when what i see as a 100% seal solution comes out of a tube and is available at nearly every store i pass for <$10 Edited by Rockatansky - 02-September-2023 at 6:16AM |
Posted: 02-September-2023 at 2:47PM |
The Ultra Copper will seal very well as long as there aren't any large gaps to fill, just a decent surface to surface match. The collectors are the worst because the flange halves are vibrating constantly, and slightly flexible. If you can get them to seal, be satisfied and don't touch them any more, plus don't rub any speed bumps etc. I planned ages ago to cut off any common three bolt flange, and weld on v-band flanges. Those interlock securely and shouldn't ever leak.
Greg73Oregon
Joined: 23-February-2021 Location: Roseville, CA Status: Offline Points: 232 |
Posted: 04-September-2023 at 8:13PM |
I used Ford Performance gaskets. Didn't have any issues. But I have stainless steel headers.
GKF
