  New Posts New Posts RSS Feed - Weatherstripping
Weatherstripping
NwOh_Starsky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Topic: Weatherstripping
    Posted: 11-September-2013 at 12:38PM
So I like almost anyone with a sedan or wagon had very leaky windows when I got my Torino.  I read and searched everywhere and came up with the same answers I'm sure everyone has seen...not much. I tried the PlastiDip, even tried cutting the back ind inserting rubber vacuum line to try to seal the gap. No luck.  I bought a roll of universal 3M self-adhesive weatherstripping - part number 8651.  It didn't quite fill the space the OEM weather seal filled, but it sealed the window! It is available in many part stores.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2013 at 12:46PM
Nice find!
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2013 at 12:50PM
Nice find!
Not a show car fix, but since mine's a driver it's good enough.  I've been thinking about filling the gap with black RTV or something so it looks a bit better.  I overlapped the corner a little to help fill the area under the corner of the glass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2013 at 12:54PM
Here's a few other pics:
Window up
Front of window track
JoeKarasinski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeKarasinski Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2013 at 2:08PM
I don't know if this would help but you might be able to make something closer with one of these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2013 at 1:13AM
Looks like a similar product, just different shapes.  I'll give them a good look over before doing the other windows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2013 at 1:59AM
Wow, this is what I have been looking for. The original owner filled the gaps in the original weatherstripping on my wagon with Great Stuff. Obviously did not work, as the car leaks badly.
theomethod View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote theomethod Quote  Post ReplyReply Direct Link To This Post Posted: 19-September-2024 at 12:01PM
Hello,
I work for a police department and we are trying to restore a 4dr, 1976 Torino as a police car for an anniversary celebration. I need help finding window seals, can anyone assist?
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2024 at 9:40PM
 far as i know nobody makes any of the seals for the 4dr'sCry
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2024 at 7:07AM
I have been looking for good seals as well ever since I got my wagon way back when.
Every now and again I'd come across some NOS stuff on EBay, but I havent seen anything in the last few years.  Ya also have to remember even the NOS stuff, if you can find it, is 50+years old. Ouch
Please post if you find something close that will work.
Good luck on your project! Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2024 at 11:46AM
For the rear window on the wagon, I used this stuff:
I wish it were a little thicker so it would seal better at the bottom of the window, but it seals fine at the top of the window. I then used peel-and-stick foam weatherstrip from Home Depot for the metal part of the tailgate, which I could stack to get more thickness.
For the windows, I bought the seals for a 1973-74 LTD from Rubber the Right Way. I cut it to fit the driver's door, but when rolled up, the window wasn't pressed up against it. I have since adjusted the window, so I might try again. In the meantime, I used gray putty to fill in the gaps on the old window seals, then colored it with a Sharpie, but that ink never stays dark, and I still have hella wind noise on the highway.
