  New Posts New Posts RSS Feed - Convert to manual steering
JBR-3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBR-3 Quote  Post ReplyReply Direct Link To This Post Topic: Convert to manual steering
    Posted: 12-December-2024 at 3:50AM
Well I might, I'm looking into it.
What I have is 1973 power steering, what I want (maybe) is manual steering.
I did some searching and didn't see what I'm looking for, so here's the question:
Are the centerlink and idler arm the same for both power and manual in 1973 ?
I know the box and the pittman are different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 12-December-2024 at 9:24AM
The Ford parts catalog shows only one listing for the idler arm and center link, so you are good.  You should just need the steering box and pitman arm.  I am pretty sure Rockatansky did this conversion as well, so he might have some additional insight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-December-2024 at 11:03AM
i sourced the gear box from Blue Oval 6079 parts when they had a website, looks like they're only selling on ebay now?
i found a rebuild tutorial online, seals from a local bearing house. the grease is specific-ish, they said you want the basic drum brake wheel bearing grease not any latest & greatest stuff. an inch-pound torque wrench is needed to check the preload
Edited by Rockatansky - 12-December-2024 at 2:07PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-December-2024 at 2:06PM
jglover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jglover Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2024 at 10:07AM
I have a 1972 that has manual and want to add power steering!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-December-2024 at 2:16AM
You guys should swap parts then!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBR-3 Quote  Post ReplyReply Direct Link To This Post Posted: 16-December-2024 at 5:24AM
I want to say thanks for the help !
I'd like to keep my power setup just in case I don't like the manual steer,
then I could switch back. I'm a ways off from the swap though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 16-December-2024 at 12:01PM
my pic of the seals didn't get through
there it is
