  New Posts New Posts RSS Feed - Hood Scoop Template
Hood Scoop Template
piper62j View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Topic: Hood Scoop Template
    Posted: 06-July-2019 at 1:41AM
Does anyone have, or know how to obtain a template for the non functional hood scoop for the 68 - 69 Torinos?  If that's not available, are there dimensions that can be used instead? I just picked up a complete OEM unit with lights and would like to install it on my 68.
Thanks in advance..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2019 at 11:56AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2019 at 1:55PM
 that would probably work for non functional just don't cut out the 4 ovals Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2019 at 3:20PM
the 68-69 scoop is non-functional anyway, even with the holes cut out.  I have  saved the center section of my old scooped hood so I can trace the actual holes for you.  Send me a private message to remind me as I am away from home for a week.
(Non-functional as in “ no flaps to open/moveable parts/etc.....”.  It is “functional” in that turn-signal indicators are in it and blink with the L and R signals)
Dave Fox
Edited by hogfiddles - 14-February-2025 at 6:34AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2019 at 2:50AM
I believe I have found the correct template for this application. The seller does not indicate the vehicle type, but the template is a perfect match for my oem non functional scoop.. Purchased it and will update you on how things work out..
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2019 at 5:27AM
that just shows you the bolt holes and the turnsignal holes.... it does not show you the 4-hole oval.  The oval is there regardless of whether it is a "functional" scoop or not.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2019 at 7:01AM
Hogfiddles.. You are correct. I was searching on line and actually saw the 4 large holes in the hood.  I'm not going to cut those out.  My hood is original and fits perfectly, so the mounting holes and small bulb access holes will do for now.. Thanks for the update.. Good catch..
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 20-July-2019 at 3:15PM
ok, cool.  If you do decide to make the rest of the cutouts, let me know.  I saved the center of my old hood, so I can always trace the EXACT shapes
CobraJoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 31-January-2025 at 2:40AM
I know this is an old post, but I have searched everywhere with no luck. Does anyone know where I can find this template?
Thanks in advance.
1968 Torino GT F Code
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 F150 SuperCrew,
2025 Edge Platinum
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2025 at 6:36AM
Yep.... I have one— but you know that, since I traced it for you ;)
I’m posting this so others know you’re all set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2025 at 10:26AM
Thanks again Dave; just came in the mail this afternoon.
I'll be at the body shop tomorrow making the cutouts.
Again, I can't thank you enough.
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 Edge Platinum
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2025 at 4:31PM
Mock things up first before you drill and cut, just to double-check…….. It should be right, cuz that’s the pattern, but if anything seems off, I’ll do a tracking impression of the actual hood openings themselves since I saved that hood section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 15-February-2025 at 1:30AM
Thanks, will do. Unfortunately it won't happen today as the bodyshop is closed, the owner went up North with his wife for the weekend.
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 Edge Platinum
ELT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ELT Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2025 at 2:49AM
Here's a pic of my 69 hood with scoop removed. Hope this helps.
Thanks,Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2025 at 12:35PM
Thanks guys! I went to the body shop and marked all the cutouts onto the hood. The bolt pattern for the aftermaket scoop is a little off on one side vs the other, but will be okay.
I'll probably go over one night this week and cut them out; still contemplating doing the four cutouts to make the scoop functional?
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 Edge Platinum
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2025 at 1:49PM
If you cut out the four holes to make the oval, don’t cut out the center ‘cross’. The four factory holes make the oval with the cris-cross in the center.
Again, if you need to see a pic of the actual piece from my hood, I can take one, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2025 at 12:40AM
No need Dave, what you sent works out fine.
I'm glad you posted that pic though, I didn't know that there were reliefs cut into the brace.
Thanks again,
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 Edge Platinum
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2025 at 4:30AM
Keep in mind, if you decide not to cut the holes the scoop will hold any dirt/crud and hold moisture and eventually rot as it is what mother nature likes to do.
ELT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ELT Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2025 at 11:01AM
Just got this ram air Cobra in October. Took the Scoop off and the previous pic shows what I found. I guess some previous owner cut the cross section out.
Thanks,Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2025 at 11:09AM
The pattern I gave you is a little off??
If you need me to make a tracing of the actual holes on my hood, I can do that, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2025 at 11:33AM
Definitely going to cut the 4 holes out; I have them all traced and just need to get over there and get them done.
Thanks again to everyone!
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 Edge Platinum
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2025 at 11:38AM
FWIW if you have no need i'd recommend not cutting the hole open to allow weather into the engine compartment and seal the bulb hole areas completely. unless you treat the car as a Roadster (convertible with no top), with the hole open eventually your air filter housing and engine bay will look like that of a car in the junk yard. been there done that. is there enough of an edge surface to seal the perimeter of the scoop to hood to prevent vibration from wearing the paint?
Post Options Post Options   Thanks (0) Thanks(0)   Quote schufitz Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2025 at 4:13AM
The GT scoop on all but ram air cars should have a seal behind the small grille to keep the elements from getting in there.
I believe the Ram Air cars had the 'cross' between the pie shaped holes cut out at the factory to allow for air cleaner flapper clearance.
ELT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ELT Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2025 at 4:43AM
Thanks. That makes sense. The hole looks to be original. Not a chop job.
Thanks,Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2025 at 7:31AM
This one here looks correct:
http://www.2040-parts.com/1968-1969-ford-torino-ranchero-functional-hood-scoop-template-428-cj-scj-bbf-i296116/
Vince-
Watch 2040parts. Believe they are a scammer site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2025 at 8:40AM
I already gave him a copy of my template
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2025 at 8:41AM
Correct…..but the fiber-y flat seal gets hard and dried out over the years.  I think mine is still sort-of there
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2025 at 1:13PM
Thanks guys, I will probably remove the fiber seal (it only has 3 screws)  as my car will probably never see the weather.
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 Edge Platinum
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 19-February-2025 at 1:59PM
If it has the block off plate and you don't want to cut the hood, you could seal the seams well to the hood, with Ultra Black RTV. It doesn't take much to seal, put a decent bead along the inner perimeter, wipe the outside well with a prep solvent, and seal the block off plate easily from inside.
RaydarNJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RaydarNJ Quote  Post ReplyReply Direct Link To This Post Posted: 21-March-2025 at 11:01PM
New to the forum. I want to add a hood scoop to my 1969 Torino GT convertible but need a template for the body shop.  What is the best source?
This page was generated in 0.189 seconds.
