  New Posts New Posts RSS Feed - Wiring help - fusable link burned out
Dubz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dubz Quote  Post ReplyReply Direct Link To This Post Topic: Wiring help - fusable link burned out
    Posted: 03-July-2025 at 7:08AM
I was poking around under the hood today to wire up my electric choke, and I found a burned up wire when I pealed off some electrical tape.
The wire itself is connected to the sta post of the alternator (the sta wire also has a factory y off into a different set of wires).
Burned wire goes to this connector on the passenger side of the engine bay:
The only non-burned wire in this set connected to anything is the red one that runs to the starter solenoid.  Other end goes to the empty harness shown below
What wire have I burned up?  Could I solder in a modern fuse holder instead, if so, any idea what size fuse? ( Blue block on the wire says "fusible link 20 ga")
Edit: the car still starts fine, so I'm not sure how long this may have been burned out for before I found it today, possible it's been this way for years!
Edited by Dubz - 03-July-2025 at 7:52AM
1974 Gran Torino in flat black 351W/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2025 at 1:57AM
Have you looked at the wiring diagrams?
My '72 doesn't have a plug like that so I am not recognizing that wire off the top of my head.  If you can't figure it out, I will take a look at the diagrams when I have some more time.  CaliforniaJohnny is more familiar with the later Torinos, he might know.  Why not just replace it with fusible link again?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2025 at 2:09AM
 I believe the alternator's STA stud and it's wiring goes to the carb's electric choke. Here's a wiring diagram showing as such, it is from a '75 Ford shop manual but hopefully it is helpful.
pyntre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2025 at 4:44AM
A new fusable link or a maxi fuse . But FIRST !!
You have to figure out why the original fusable link
took a hit and burnt . Obviously a serious short to ground on one of the main circuits!
Find that first !
