  New Posts New Posts RSS Feed - '72 Outside air duct
jglover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jglover Quote  Post ReplyReply Direct Link To This Post Topic: '72 Outside air duct
    Posted: 28-November-2025 at 7:57AM
Does anyone have a picture or diagram of the driver side outside air duct.  The cable on mine is frozen and I would like to pull it down and get it working.  I would like to know where all of the mounting screws are so that I am spending minimum time under the dash.  Not easy being old!
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2025 at 2:09PM
I have a 73 but I believe it's the same as the 72.  I have two pics that will hopefully assist you.
The vent cable handle is mounted to the underside of the dash with I believe 2 screws.
Second photo shows the cable as it runs just to the side and above the fuse box where it attaches to a metal bracket with not sure if one or two bolts.  The cable end then attaches to the vent lever but I can't quite remember what secures it.  Hope this helps.
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2025 at 2:19PM
There is an NOS cable on Ebay with a pic that shows the end of the cable.
I believe the cable end just slides onto the vent lever and a cap slides onto the end of the vent lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 29-November-2025 at 2:36AM
Let me know if you want me to try and dig up the factory diagrams or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jglover Quote  Post ReplyReply Direct Link To This Post Posted: 30-November-2025 at 5:14AM
This is exactly what I needed.  Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 30-November-2025 at 6:38AM
Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote jglover Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2025 at 2:41AM
The square end that hold the handle was bent.  A little hammer work and some WD40 and it work fine.  Thank you again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 17-December-2025 at 2:44AM
Thumbs Up
