  New Posts New Posts RSS Feed - 07 Mustang Help!
07 Mustang Help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Topic: 07 Mustang Help!
    Posted: 01-June-2010 at 1:23PM
The wife traded her truck for an '07 Mustang V6 over the weekend.
What is the best Mustang website for technical info?
Issue we have is the 3rd brake light is not working, nor are both outer brake/turn signals on both sides in the rear. Bulbs are all good.
There has to be a fuse or something that runs all of these. The Brake lights all seem to have seperate wires not just a common wire for all 3 bulbs on each side.
ANYONE have info on this??
I am sure it is a common Mustang problem or easy fix if I knew what to do/where to go.
Also need a tire pressure sensor and band for one of the rims.
The tire shop said 3 of the 4 wheels have the sensor&bands but the RR does not.
Amazingly, the indicator light is not on!!!??
THANKS!
302ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 302ford Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2010 at 3:11PM
I use Corral.net ....
Best for info by far....
79 LTD II 408/TKO/3.7's
11.78 117.3mph. drag radials
occupant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote occupant Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2010 at 2:44AM
http://www.allfordmustangs.com/forums/
http://www.3.8mustang.com/forum/index.php
http://mustangforums.com/forum/index.php
All have millions of posts in hundreds of thousands of threads.
Corral is nice, so is StangNet, but those three up top in my post here, those are the best for V6 owners IMHO.
