  New Posts New Posts RSS Feed - MIG Welder help
MIG Welder help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Topic: MIG Welder help
    Posted: 01-August-2010 at 2:45PM
Need to buy a new MIG Welder.
Will be used for body work, custom fabrication and roll bar/cage work.
The 130Amp one I have has broken and I never did put on the gas portion.
This is a GREAT price from what I have found.
It is a 135Amp, should have no problem welding up to 1/4"
What do y'all think?
72BlackGTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72BlackGTS Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2010 at 4:57PM
Carl, I think thats a great deal. Helmet, cart, good welder and free shipping to your door. Can't beat that deal with a stick!
I paid $500 with free shipping on my Lincoln 175 but it's 220 volt. I also did not get a cart or a welding helmet. I rent my tank of gas. No one here will fill a private owned tank. I  traded my oxy/ace tanks in for free rental on them. I just pay for the gas when I need them filled.
Good luck.    Ron
Ron
1978 LTD II Sport-Green
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-August-2010 at 6:00PM
looks like a rebadged Lincoln, very similar to my WeldPak100 machine. i don't see any mention of drive rolls or capability of running .030"/035" wire? if it is a Lincoln, it probably has the flippable drive rolls like mine but you may want to call Eastwood to verify. fluxcore capability is pretty handy if you should run out of gas & need to do a quick job that doesn't need to be pretty.
not a bad deal at all especially if you want the cart(i made a cart for mine) & helmet. you can save $100 w/o the cart if you go to a Chicago Electric or other discount tool house brand  but the 3 yr warranty, cart, helmet & free shipping make up the difference if you need em not to mention the Lincoln? quality
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2010 at 12:35PM
Well just spent under $100 to repair my Astro 130. Instead of buying a new one.
New tensioner and parts, and a new wire sleeve.
This page was generated in 0.129 seconds.
