  New Posts New Posts RSS Feed - engine casting number  location.
kversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kversch Quote  Post ReplyReply Direct Link To This Post Topic: engine casting number location.
    Posted: 20-January-2011 at 12:36PM
where can I find the casting numbers on a 302?   I want to ID   the 302 so I know exactly what I am dealing with.    according to the previous owner it is suppose to be a 69 302 from a mustang  so I should find  a casting number reading something close to  C9ZE-****-*
-kevin-
Brown 72 gran torino 351c 2v
Black 73 GTS FB 302
Red 73 GTS FB 351C C6 trans
73 GTS FB Parted
73 torino 4dr, 302, FMX parted
97 F250 crew cab 7.3 diesel
http://kverschtorino.blogspot.com/
Blueoval76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2011 at 1:07PM
Correct on the number. It is next to the pan rail above the starter. Right in that pass. side rear corner of the block.
03 Bonneville some mods
Post Options Post Options   Thanks (0) Thanks(0)   Quote kversch Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2011 at 2:20PM
Thanks blueoval,     crawled up under the car, just enough room to squeeze under with out jacking it up and took a look.      after some brake cleaner and a bush   to clean the gunk off i found the numbers.
C8AE-6015-A       and another number i think it read, 8O22.           so this is not a 69 motor  but a 68.
its a 68  ford engine    and its an original engine.    The 8O22 would be the date code correct?     so   October 22, 1968  would be the date it was cast at the foundry?
so how can I determine what it came out of??
-kevin-
Black 73 GTS FB 302
73 GTS FB Parted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2011 at 2:33PM
Here this should help a little bit more.
occupant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote occupant Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2011 at 3:49PM
A late 1968 code tells me 1969 car. They usually changed over in summertime. You wouldn't see an October 1968 engine in a 1968 car if the car was built in what, as late as July or August? By October they were building 69's...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2011 at 3:56PM
yup August 68 is a 69. Same for most years... August is the usually the cut off. SOME are also cut off in July making them the next year as well.
This page was generated in 0.079 seconds.
