  New Posts New Posts RSS Feed - 460 SWAP
460 SWAP
Scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott Quote  Post ReplyReply Direct Link To This Post Topic: 460 SWAP
    Posted: 31-August-2012 at 3:25AM
I have a 1976 S&H LE that I am wanting to put a built 460 in and would like some help on an intake.The car will be a weekend driver and car show car but I may take it to track sometimes.I would like to know what is the best intake to run on the car that will still fit under the stock hood.I plan on a good size cam bored .030 and a Holley carb with Hooker supercomp headers.This will be my 1st big block ford motor.I have always messed with 302 or 351W.Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2012 at 4:49AM
Scott,
 A good all-around aftermarket intake to use that won't interfere with the hood is an Edelbrock Performer. It isn't the most powerful intake out there for a BBF but it does very well for a daily driver. I have used this same intake and using a 1/2" carb spacer with a 14" air cleaner with a 4" tall filter (Fram CA3492 for example)the hood will still close no problem. It kinda depends on many things including engine mount manufacturer and/or air cleaner base design as being the two biggest factors. Todd
Edited by aquartlow - 31-August-2012 at 4:50AM
This page was generated in 0.073 seconds.
