Engine install bolts??? |
| Author | |
GranTorinoSport
Admin of "The Org" Joined: 20-May-2003 Location: Seattle Status: Offline Points: 2290 |
Topic: Engine install bolts???Posted: 04-July-2013 at 8:35PM |
Ok guys another question.
Since this is not a replacement engine but rather an upgrade from a 351W/c-4, I do not have bolts for engine to bellhousing and also the flywheel bolts that mount to crankshaft. I notice arp has the flywheel bolts but not the engine to bellhousing bolts which are just a basic 7/16-14 at 1 1/4 inches in length. What did you use for both sets of bolts in your car? |
Webmaster |
Posted: 05-July-2013 at 2:30AM |
bring 'us'(me) up to speed again what's going in place of the W/C4 ? likely the same flex to crank bolts will work for any motor to a C6 ? I used local hardware grade 8 bolts(overkill) to snug up my C6 bell. not factory appearing with the gold iridite plating but I suppose a little black paint would help... or, i'll bet someone here has a stash of factory bolts that'll fit into a std rate box
Regul8r
Moderator Joined: 26-December-2007 Location: Sarasota FL Status: Offline Points: 6624 |
Posted: 05-July-2013 at 4:20AM |
I would definately use the ARP bolts for the flywheel to crank.
If the torque converter is bolts and not studs with nuts... Grade 8 all the way Same for the bell housing... a set of Grade 8 and forget about it.
Joined: 19-December-2011 Location: Summerfield, Fl Status: Offline Points: 2341 |
Posted: 05-July-2013 at 5:44AM |
Great advice ^^^. Stock 460's (at least all the 429-460s I disassembled) came with a "reinforcing" ring that goes onto the flexplate after you place it onto the crankshaft flange, it spreads out the flexplate/flywheel attachment bolt torque to avoid cracking or metal fatigue of the flexplate. I would recommend using it if possible. Todd
Psquare75
Member of the Stroker Club Joined: 26-November-2005 Location: United States Status: Offline Points: 4591 |
Posted: 05-July-2013 at 5:55AM |
I think I have some bell bolts from when I did the TKO in my F100.
Robbdtme
Joined: 06-June-2012 Location: Central WI Status: Offline Points: 765 |
Posted: 05-July-2013 at 7:13AM |
I would check on the flywheel aren't 351's externally balanced at 28oz on each end or is that just front harmonic balancer?
Edited by Robbdtme - 05-July-2013 at 7:15AM |
GranTorinoSport
Posted: 05-July-2013 at 8:57AM |
The 351w is sitting outside still. But I do like the idea of getting the arp bolts for the flywheel, new bolts with a high torque engine is always a good thing. New converter came with nuts on it already. I will get some grade eights if needed but was hoping to find some black oxide or something slightly better quality. I can't believe of all the bolts arp makes that they don't have those.
There is an outfit I saw mentioned on 460ford.com called Lem Evans or something. Might give them a call Monday. |
Webmaster |
Regul8r
Posted: 05-July-2013 at 3:56PM |
Scott, if the converter has STUDS on it then regular lock nuts(Grade 8) will work. The studs are what takes the power. no worries
