  New Posts New Posts RSS Feed - Grease fittings on driveshaft
Turbo301 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Topic: Grease fittings on driveshaft
    Posted: 03-August-2013 at 12:45AM
I was recently under my car (1977 Cougar) for some maintenance and for the first time I noticed grease fittings on the driveshaft joints! I've never seen a car with fittings here, and not even the factory manuals talk about applying grease to these joints.
Do other people have grease fittings on their shafts, and if so, how often do you grease them? Is standard chassis grease okay to use?
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2013 at 2:48AM
yep, I assume you are talking about the u-joints?  just grease them when you grease the front end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2013 at 3:19AM
I do as well. Greased every oil change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2013 at 8:11AM
Thanks, guys. Any idea why the manuals don't mention this as a greaseable location?
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2013 at 9:13AM
Most likely the factory u-joints didn't have grease fittings and over the years someone changed your u-joints with an aftermarket u-joint that has grease fittings. -Rick-
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2013 at 9:20AM
So they're not a factory thing?
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2013 at 4:05PM
not a factory thing on our cars.
but hit or miss as some cars/trucks do or don't have them from the factory.
This page was generated in 0.080 seconds.
