  New Posts New Posts RSS Feed - californiajohnny's other cars
 Post Reply Post Reply Page  <1 5678>
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-November-2020 at 4:13PM
also hand formed some tail light filler panels made from the old sheetmetal from my torino hood and frenched in some 89 cadillac deville tail lights with LED conversions too Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2020 at 6:34PM
spent 2 hours last saturday doing the bodywork on the tail lights and sprayed some primer on there to drive to the last cruise night... the lighted xmas cruiseBig smile i was drying the primer with the heat gun just before i leftLOL i didn't put lights on my vehicle... i have lights underneathThumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2020 at 6:35PM
Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2020 at 8:21PM
today i added green LED's to the dash cluster Wink and pulled the pioneer cd player out to add this $8 adapter to add an auxiliary ipod input to the older pioneer stereoThumbs Up that didn't have an aux input!  now i don't need to replace that stereoClap
For PIONEER IP-BUS AUX INPUT ADAPTER CABLE to 3.5mm AUX CD-RB10/20 MP3 Pio35 super easy to do Big smile BUT you must program the setting in the stereo for it to work!!! but super easy to do Wink
 here's a video i found showing how to do it... (btw he has the same exact stereo i have) but it should work on any pioneer supertuner if it has the blue 10 pin ip bus receptacle in the back Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2021 at 7:47PM
a few days ago i swapped out the original Mitsubishi distributor for an mid 80's ranger dist. as i suspected the Mitsubishi cheap coil of wire style pick up reluctor may be starting to fail like it did back in the mid 90's... so with some wiring from an 80's f150 generously donated by pick n pull LOL i wired the ranger dist. to an accel GM HEI module mounted to a custom aluminum heat sink on the fenderwell and an aftermarket  50k coil Thumbs Up
 runs good but now i need to upgrade the electric fuel pump, as i also upgraded the carb from a 32mm to a syncronized dual 38mm! is runs out of fuel in the carb midway through a third gear burnoutConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-February-2021 at 12:38PM
brief updates: a couple weeks ago i upgraded the electric fuel pump on the courier... yep that was it!  i was able to do a burnout in first..second..third..and fourth gearBig smile
 finally stopped procrastinating and replaced the weak clutch in the nissan with a stage 2, 6 puck ceramic disc and stronger pressure plateBig smile now to find the miss at idle... 260K does have me concernedConfused
dan0R30 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan0R30 Quote  Post ReplyReply Direct Link To This Post Posted: 28-February-2021 at 12:45PM
CoolThumbs Up
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M. Quote  Post ReplyReply Direct Link To This Post Posted: 01-March-2021 at 1:01AM
It never ends.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2021 at 4:40PM
ok some recent updates: finally figured out the miss in the sentra... after a new distributor (not the problem) and a clogged #4 injector, dried to clean it and while energizing it smoke came out of it Shocked so i ordered 1 from the parts store but picked up on when i was in another town, replaced it... working good, next day missing again #2 intermittently working, went to the local parts store to get the one they orderedWink they ordered 2 so i grabbed 1 installed it (used way too much grease on the o-rings so it was smoking blue for a few minsOuchLOL) drove to town to get another bottle of 75/25, run great until i got back and pulled into the local parts store to tell them... started missing real bad and i could smell gas ( it was coming out the tail pipeShocked) so i got the extra one they ordered to swap it out for warranteeConfused now you know why i hate EFI!!!
 so far it still working good! we'll see......
so onto the courier... a few weeks back i had issues with the drivers rear wheel heating up, cleaned and lubed the Ebrake cable, new brakes, took it for a 50 mile cruise with the group out to a town at the very west end of our county, out of habit i checked the rear wheel, hot again Shocked knowing it not the brakes this time it has to be the wheel bearing?
 ok fast forward to last saturday... on my way to the cruise night and local mini truck photo shoot, as well as a quick stop on the way for another brock's garage filming... everyone's waiting... get a block down my road boom it just diesShockedShockedShockedShocked hmm seems that the module diedAngry got a ride back home grabbed the cheap bad one from the garage and throw it on... fires up, i take off Big smile got almost into town it dies againAngry turned the key off and restart it and go some more... dies several times in the next few mile to the filming location, after that my buddy john says he has one at home i can tryThumbs Up well it dies like 7 times across town get to his house and put his on, fires up and runs great, so i decide to continue on to the cruise and photo shoot later... not an issue there and back Big smile ok i figured may i need to improve on my heat sink design and over build it for extra insurance Wink that brings me to this week...go to the parts store and ask if the premium module is lifetime guarantee??? they said YES and the first crappy one has a 1 year on it so i found the box and returned it Thumbs Up but being master fabricator... i took a old computer fan that runs 12VDC and mounted it above the new module to help cool it WinkBig smile
 which BTW worked great this last sat night as the cruise was 109*Shocked that evening
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2021 at 4:44PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2021 at 4:56PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2021 at 6:41PM
 BTW i forgot to mention i think the real issue with 3 modules was the fact i later discovered the positive wire to the coil had came out of the connector ( probably more chinese made stuff with a serious lack of quality control ConfusedCry)
 and i still need to pull the rear axels and pack those bearings with grease... ( yes you read that correctly! after some research i've found that those run in grease much like front bearing do Shocked) IDK never messed with the diff in the 30 years i've owned it....
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-July-2021 at 7:08PM
yesterday i finally decided to remove the front damaged bumper on the sentra to repair the fiberglass that got damaged about a year ago when some guy backed into it while parked at the hardware storeAngry it required repair of the fiberglass and repaint and clearcoat...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-August-2021 at 5:52PM
i should be picking up a new toy tomorrow or should i say tool Big smile
     stay tuned......
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2021 at 8:45AM
   Let me guess. A flatbed tow truck?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2021 at 9:07AM
Shocked no but close!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2021 at 9:19AM
Is it a car trailer, and I need to borrow it a few times later this year?
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2021 at 10:01AM
Car crusher?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2021 at 10:55AM
no, i built my own trailer 21 years agoWink
Edited by californiajohnny - 20-August-2021 at 11:18AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2021 at 10:56AM
Car crusher?
  nope....
AUS GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2021 at 11:20AM
Well that was an interesting read...youre a man of many faces Johnny, good stuff!
Might have to put up one of my unusual past rides.....
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2021 at 7:57PM
here it is: 88 F450 wrecker... 7.3 diesel, 5 spd, wheel lift, and 12,000# winch Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2021 at 10:51PM
King of the road! would like to do an interstate trip in that one.
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2021 at 1:51AM
That should be fun.
I would get in SO much trouble....
(Neighbor pisses me off, I tow their car. Maybe leave it in a bad part of town...)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2021 at 4:07AM
LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2021 at 4:09AM
   I was as close as it gets. Haha.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2021 at 7:19AM
Dual Stack Mini Mack Thumbs Up
GV overdrive and make it a 10 speed Big smile
it needs a Humping Rhinos hood ornament for sure LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2021 at 7:22AM
Nice find John!  I love the 7.3 Navistar diesels (especially the Turbos), great engines.  I am assuming yours would be non-turbo based on the year (I think 1994 was the first year).
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2021 at 8:41AM
yep IDI i think is what they call them
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2021 at 10:28AM
Yeah, IDI - Indirect Injection.  They did make a 7.3L Turbo IDI breifly around 1994 before the Powerstrokes came out.  My buddy had a 1994 F-250 with a 7.3 IDI turbo.  It was a great truck, tons of pulling power and not as loud as the Powerstrokes.
