  New Posts New Posts RSS Feed - Cvf racing brackets
Cvf racing brackets
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Topic: Cvf racing brackets
    Posted: 23-February-2015 at 4:39AM
Just got my new CVF alternator 351c bracket kit.
For the money seems quite top notch, nice feel.
Need to send out for powder coating yet before my install.
Hung up a bit due to was planning on buying a 351c BEAST serpintine 8 rib belt drive but had other issues requiring money.
If any of you have their stuff post up pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 15-November-2015 at 8:40AM
maybe i'm late to this post, but, i have the CVF pulleys and p/s pump bracket and housing on my 351W
Edited by californiajohnny - 15-November-2015 at 8:59AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2016 at 2:49PM
John-
Do you have any other pictures of the area of the back side of the reservoir? I'm curious how it's connected to the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2016 at 2:57PM
andy, i don't think i do, but you can see the edge of it where it's bolted to the block, in that pic! all it is is a 4" long straight aluminum piece about 1/4" thick IIRC it attaches around the center fitting at the pump and has a slot on the other end (that you can see in the pic)and there is about a 1/4" spacer between the bracket and the block
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2016 at 2:54AM
Ah ok.
I really like the look of that but I switched over to the later 70's plastic reservoir pump.
Hmmm something to consider.
What's mildly amusing is CVF said originally not to use the Thompson pump with their bracket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2016 at 11:45AM
what? it's for that pump! Shocked but i'm not sure if i have the pulley on right, i had to swap v-belt grooves for it to line up.
MarkGubinski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkGubinski Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2016 at 1:23AM
I used CVF brackets on my big block race car for an alt. A little pricey, but good stuff that's strong & fits.
72 Gran Torino Sport 557
10.12 @136 @3600lbs.
2 Time Milan Dragway Track Champion.
2012 IHRA Div. 5 No-Box Champion.
97 career wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2017 at 4:57AM
A little old on this post but I finished my swap last year and have around 5K miles on it.
Overall, quite happy. Need to upload a few more pictures but off their site:
http://s80.photobucket.com/user/Eliteman76/library/1972%20GTS%20Torino/Drivetrain/Belt%20Drive
Edited by Eliteman76 - 10-January-2017 at 4:58AM
This page was generated in 0.074 seconds.
