INFO: 65 Mustang Floor Pans Work on 1972+ Torinos |
Post Reply | Page <12 |
Author | ||
yes this is the thread i was referring to! carl, can you throw a sticky on this!!!
Regul8r 2
Admin Group Joined: 02-February-2016 Location: Rapid City, SD Status: Offline Points: 447 |
DONE
Owner- www.CaNDeCustoms.com |
JFN
New Member Joined: 23-January-2022 Location: Du, Status: Offline Points: 3 |
So did the original rails for the front seat fit back in place or did you have to modify the rails to make the original seat fit?
hogfiddles
Moderator Group Moderator Joined: 19-September-2016 Location: Central NY Status: Offline Points: 1514 |
you need to re- install the seat-rail supports that go across the top of the floorpan.
r9b2
Member Joined: 16-June-2021 Location: Maine Status: Offline Points: 68 |
Thanks(2)
Just wanted to throw in some more evidence of this working, if that's okay with you guys. It took a long time because of the base Auto Hobby shop only being open two days a week, but I threw both sides of '66 Mustang floorpans in my '73 Torino. After: |
1973 Ford F100 429 1966 Ford Mustang I6 2013 Subaru Forester |
Compton
Senior Member Joined: 22-April-2017 Location: Auckland Status: Offline Points: 629 |
Thanks(2)
Might as well jump on the bandwagon and second that…however I used 71-73 as they don’t have the holes for the seats to bolt through so one less thing to weld up or plug
Full left and right pans were used which basically dropped straight in and then stitched into the footwell |
Thanks for posting these pics guys, much appreciated.
Wayner315
Senior Member Joined: 19-October-2021 Location: Alberta Status: Offline Points: 216 |
Thanks for these pics. I might have ordered those ridiculous Torino patch panels sold everywhere but this seems much better.
72 Gran Torino formal roof Brougham
Compton
just an update on the pans...originally got a set of coupe/fastback and a set of convertible as they're slightly different...Chopper test fitted both and went with the convertible as they fitted better...
RacerJames
Member Joined: 25-April-2022 Location: 86401 Status: Offline Points: 50 |
This is very cool!
Made me wonder if maybe the '79 and up LTD/Crown Vic floors would work as well?
'73 Torino Stock Car
'71 Mustang Stock Car 351C powered |
hogfiddles
I bet you’ll be the first to know, and report how to do it ;) Dfox
RacerJames
Fortunately for me, I live in rust-free AZ. I never knew what this meant until I relocated from SLC. Its a world where rubber and plastic disintegrate, but steel remains unchanged. I could probably supply a rust free car that someone could then experiment with!
72MLC
New Member Joined: 10-December-2021 Location: Memphis Status: Offline Points: 39 |
I cannot find anyone here local for work or advice, so may have to get a friend to just dive in and help eventually. I have the pans but where do you find the seat floor supports? Or were they fabricated? Only can find one website and it's a non secure one, so looks like a no no. Thanks!
Compton
Chopper fabricated a hybrid seat brace from factory (over the drive tunnel) and new as I’m using 69 Mach 1 seats…you can use the factory brace you just have to set the pans to the lower height of the brace…
72MLC
Thanks! Finally found a place today accepting work, so looks like I should be getting on the books sometime tomorrow.
stumpnc
Brand New Member Joined: 02-May-2023 Location: North Carolina Status: Offline Points: 1 |
Did you use the left pan on the right and vice versa as mentioned above?
I ordered a set this morning for my 73 Ranchero project Any pointers much appreciated!
