  New Posts New Posts RSS Feed - INFO:MSD 6AL Points Trigger/OEM Tach/Duraspark/HEI
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2017 at 12:49PM
Todd mentions he used the TFI coil with .5 ohm resistance in his setup with an HEI module.  The HEI modules need a low resitance coil.  Coil selection seems to be very important for the module to work properly.
Here is some comparisons on an HEI module firing different coils.  As you can see, the higher resistance coils produce much less energy.  This results were performed with a standard GM HEI 4-pin module, which limits the current to about 5.5-6.0 AMPS.  Some aftermarket HEI modules have higher current limiting of 7 amps or more.
This is a 0.5 Ohm coil.  Notice that the module hits the almost 6.0 amps, then levels off.  This is the current limiting feature in the HEI coil.
This is a 1.5 Ohm coil.  Notice the coil takes longer to reach it's peak, and it only peaks at about 3 amps.  This is more like the power on a points ignition that has a resistor wire limiting the current.
This is a 4.0 Ohm coil.  It probably doesn't have enough power to fire a plug.
Great info showing huge differences with minute resistance changes. I examined just about every part of my ignition system, from testing distributor cap coil terminal/rotor button resistance(HUGE variances between manufacturers), magnetic pickup, testing plug wires, even spark plug resistance varied widely between resistor plugs for my application(Autolite 45, Champion RF11YC and the NGK WR5's I am currently using(least resistance).
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2017 at 4:51PM
Clap damn todd, you are our "resident mad scientist"!!! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 23-March-2017 at 11:41PM
Nah,
 I just get bored easily Big smile, then I get up to my eyeballs with the work involved in trying to improve things, kinda like totally remodeling an entire bathroom because of a leaky faucet Confused. I know, I know, It's a disease....err an obsession Embarrassed, but it definitely keeps things interesting LOL
gentrysgarage View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gentrysgarage Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2017 at 5:16PM
I have learned a lesson today....Even if you dislike a company (in this case MSD) read the posts. It would have saved me 2-3 whole days searching the internet to  come up with what Todd described here 2 weeks ago. A side note if you have a truck Junkyardgenius.com has a great inexpensive dual battery setup.
Thanks to Todd and Vince
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 07-March-2021 at 7:04AM
There's thread........LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 07-March-2021 at 7:10AM
I think this thread should help you.  Todd's setup sounds pretty much exactly what you are looking for and I included his pictures and diagrams of how he set his up.  I believe he's also running a 3G conversion too.  The only difference would be the small cap you want to run, which some say might not work as well with the higher voltages of the DuraSpark HEI setup.
