  New Posts New Posts RSS Feed - Dash crack repair
Dash crack repair
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: Dash crack repair
    Posted: 19-May-2019 at 8:42AM
I am starting to repair my dash panel (not the pad) which has numerous cracks in it, some small and some not so small, most on the bottom edge but a few continuing up into the black middle area.  I am looking for advice on what people have tried and what the outcomes were.  I am thinking about plastic welding the back side as this looks like a pretty solid fix but not sure if this will close up the crack tight enough on the front side.  Any input is greatly appreciated -  dave
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2019 at 9:58AM
this is what i used on dash cracks Wink since the dash plastic is made of ABS oatey black ABS pipe glue available at home depot, ace, and most any local hardware store! make sure it's abs only NOT general purpose for all pipe!
3 Pk Oatey 8 Oz Black Medium Bodied Extra Special ABS Pipe Joint Cement 30917
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2019 at 10:02AM
i'd suggest using masking tape across the front side of the crack to keep glue from getting where you don't want it, as it will soften and bond to the plastic, then work it in the crack from the back side, then clamp or hold the pieces together till it bonds Wink  i've used it to fill screw holes in my dash too
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2019 at 4:22PM
Thanks for the info, John, I think what I am going to do is try the plastic welding on a couple of spots on the lower part that doesn't show and use the Oatey on the higher spots.  Does the Oateys have a fairly quick set up time?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-May-2019 at 5:49PM
 yeah, but cure overnight...
 if you were to use a clamp on each side of the crack then use another to pull the two together vertically Wink let set over night you should be good Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2019 at 10:51AM
I think thats what I will do, possibly use a clamp on it with some wax paper to hold it flat and crossways clamp to hold together, I'll give that a try  -  thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2019 at 1:20AM
my favorite ABS repair stuff! I use that for my dash, as well as any abs part for any of the bikes I work on.  GREAT STUFF!!!
papadeath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote papadeath Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2020 at 2:51PM
i was thinking about covering the dashpad itself with carbon fiber, it wont be flexible like the original pad, but itll cover up any cracks and look cool aa hell. Youll have to find someone good at it so they can get all the contours right and polish everything shiny..
75 Ranchero in progress
04 Harley Deuce stage one kit
89 Toyota pickup modded
skateboard
4 bicycles
1 scooter
2 dogs
2 stupid cats
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2020 at 3:34PM
Hope You never hit your head on it!!
