ford ranger |
fordpower
Posted: 04-October-2019 at 11:30AM |
Ok having no luck finding rad core support bushing for my 02 ranger. Eng suspension only goes to 98.Auto zone same ans. Anybody better than me could use help. I destroyed old one thinking this was a simple find.
that's not that old... you should be able to find a good one at about any wrecking yard
fordpower
have the radiator core support want the bushings.
no i meant go to pick n pull of something and remove some bushings, that's fairly new so there should be some of those trucks in the yard and they should have good bushings still!
unlike our 45 year old cars i don't have any of those bushings BUT i do have a perfect hood and tailgate for a 2000+ ranger |
far different geologic / climate / corrosion conditions from where you are Johnny |
true! but i'd think it's new enough the rubber would survive?
must be the hole in the ozone? why not just find something from Energy Suspension and get on with life? |
fordpower
They have only up to 98 called them. not knowing difference I did not order. Auto zone said same so did summit and jaz.
reverse engineer them, how tall? outside diameter? inside diameter? you can use anything from shelf stock that's close, shim them up or cut them down
Dorman has all sorts of bushings, again you can shim or cut for a custom fit |
fordpower
went back to energy suspension asked about body mounts.maybe calling it a radiator core support was wrong question see monday
they have a body mount kit, that doesn't cover the rad core support mounts? lazy B's, they should break a leg figuring it out if they don't cover the application millions of those running around out there
fordpower
If only I had not cooked the old ones getting them off. Never though I would need them. I do have a parts truck will remove those and try to match to something thanks for thoughts
Maybe look at Exploders and Sport-Trac Exploders as well.
Sport-Trac is a really a 4-door ranger
