Replacing Tires due to Age/RWL Tire Choices |
Post Reply | Page <12 |
Author | ||
How many wheels have you tried on the front? How well do you think that 15x8 and 4.5" BS would fit the front, with 255/60/15's? That's what I think I'd like for all four, on one of mine.
BadHabit351
Senior Member Joined: 21-June-2013 Location: United States Status: Offline Points: 217 |
Thanks(2)
My apoligies, sir...those fronts are 255/60-15 not 245/60-15. Brain fart. All 4 wheels are 15x8 with 4.5" back spacing. No rubs or interference in motion. I do have to jack the front up and let the suspension hang in order to get to the upper ball joints to grease. That's with the CVPI springs and 1/2 coil cut out. I had 275/60-15's on the rear. I needed more meat on the rear, so I went with the 295's (1.2" wider each). That stroker puts down some torque. They are 1/4" shorter than the fronts; but I'll step down to 245's when I replace the fronts.
1973/72 Gran Torino Sport
1971 Torino GT convertilble 2013 Ford Fusion 2004 Ford SuperDuty 2013 Mustang GT |
Thanks a bunch for that judgement of the 255/60/15's.
I plan to by four of the 15x8" Magnum wheels for one of my trucks, but the tire size and back spacing is tough to work out. The steel versions aren't in stock but those do have 4.5" BS, the aluminum wheels by Drake are in stock, but the BS is 1/4" more, 4.75" I gather. Smaller tires could use different wheels(BS) and fit okay, the bigger tires have to be on just the right wheel size.
