  New Posts New Posts RSS Feed - Manifold bolt?
Manifold bolt?
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: Manifold bolt?
    Posted: 22-July-2022 at 8:22AM
Hi forum…qq…exhaust manifold…right side…..is there supposed to be a bolt on one side where the exhaust pipe hooks up?
I had a great fight today…..still havent won!😵👍
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 22-July-2022 at 10:43AM
should be 2 studs / nuts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 22-July-2022 at 7:35PM
Ok. Thanks. Someone drilled a hole for a bolt then. The other studs are not in great condition. Can they be removed and changed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2022 at 2:43AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2022 at 3:15AM
this is the Dorman number that pops up on Rockauto for our exhaust manifolds but there may be longer studs available so check what length will work for you, and verify the method of obtaining that measurement. or you may be able to source some locally?
https://www.rockauto.com/en/moreinfo.php?pk=1261582&cc=1129306&pt=13936&jsn=570
Edited by Rockatansky - 23-July-2022 at 5:41AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2022 at 3:42AM
Wow…wax…who knew!👍 I will see what I can do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 24-July-2022 at 1:31AM
Here are some pictures my cars’ right manifold….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 24-July-2022 at 1:32AM
Another pic….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 24-July-2022 at 1:33AM
And another…(I still dont know how to upload more than one photo in a post)
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 24-July-2022 at 5:10AM
Just repeat the download procedure before you post reply and they will all be in the same place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 26-July-2022 at 9:35PM
Ssshhhhuuuuccckkkss! I tried to take of the right exhaust manifold. All went well, until the very last number one cylinder upper bolt….snap…..
Anyway….maybe still possible to get the bolt…..will post…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2022 at 3:36AM
Tip, just barely brake loose all related bolts before fully loosening any of them. The extra pressure from having some bolts out adds slightly to the others.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2022 at 11:27AM
are you working the bolts back & forth (tight / loose) and lubing as you go?
1st move should be in the tight direction, then check it in the loose direction.
smack the bolt head with a hammer and test each direction again.
a 1/2" breaker bar with a quality 6 point socket is the way to go,
a metric socket that fits tight beats a loose inch socket every day of the week
Edited by Rockatansky - 27-July-2022 at 11:36AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 27-July-2022 at 6:16PM
A six point with the little grooves at the angles will be the best bet adding to what Rock posted. Especially if they are slightly rounded off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2022 at 4:32AM
Those socket and wrenches with the rounded corners used to be a Snap-On invention. Now even the cheap China tools have them.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2022 at 6:40AM
radiused corners don't really help the bolt come loose, Snap-Off patent was to reduce stress risers and broken sockets/warranty costs. They have dazzled everyone with bullsh*t about "Flank drive" for years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2022 at 7:55AM
I was very careful during the operation. Yes….I slightly tightened first….then loosened…back and forth…carefully…used a full can of wd40 type fluid.
The last bolt was just unlucky. The bolt looked different than the others. Greyish burnt and rough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2022 at 12:44PM
probably chinesium
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2022 at 10:25PM
If I am unable to find a right side manifold…..what is a good way to fix the drilled hole for the stud? Ideas welcome.
The manifold looks really good otherwise..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2022 at 2:24AM
There are repair items made to replace a broken and seized stud etc. Find those and see if they will fit onto that one side. The one I'm thinking of is like a pair of steel bars that attach by long bolts of their own, sandwiching the ear of the collector and lower flange. Kind of like a clamp, it squeezes the old flanges(the small section where the bolt is) together with the down pipe flange. They are on Amazon and I think they were about a $25 item. I believe it requires a decent flat surface on both parts to clamp onto, but you can grind and file down that worn hole area to do that.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2022 at 9:43AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2022 at 10:05AM
That's a large variety of repair solutions for broken or stripped manifold studs and bolts.
This is the type I was thinking of. I thought it clamped the two parts together, but it just replaces the manifold stud with an interesting loop of steel;
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2022 at 3:48PM
Get a straight torch tip and burn out the stud. Tap the threads. Put the rest of the bolts back in first. If the manifold hasn't moved, it will still be sealed to the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 30-July-2022 at 12:55PM
 its drilled out...i's rethread it, or if needed drill it larger and helicoil it to the correct size, or since there's room use a bolt that is long enough to go down towards the pipe (grind part of the bolt head to fit against the manifoldWink)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2022 at 8:22AM
I got the right exhaust manifold off today. No bloody gasket!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2022 at 8:24AM
Manifold looks good. Except the drill out hole…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2022 at 1:13PM
Ford didn't use gaskets on the X manifolds
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2022 at 7:48PM
Wow…ok….that means this is original and untouched basically.
I think I will put in a gasket though….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2022 at 12:58AM
Whadyasay fellas..?
Just need an angled washer now…..
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2022 at 7:42AM
Run a tap and use a heli-coil (there is a better coil replacement system but I forget the name). That setup will work but you already have  the manifold out so why not do the other one as well?
