Could use some diagnostics help |
Post Reply | Page 123> |
lynchster
Posted: 28-August-2022 at 7:43AM |
Lots of specifics Up until the third run it had nothing but av gas from the local airport in it. I stopped at a local station and added half a tank of non-ethanol 90 to a quarter tank of av gas. So far so good other than a hard start. The fourth time (I had burned off half a tank by then) it was sputtering so badly I turned around and parked it. I added a bottle of dry gas (water?) and 4 gal of av gas. Not driven since but no improvement. Engine specifics (nothing radical) Block: 72 351C, .030, decked, studded, balanced rotating assy
Heads: 70 351C, closed chamber, shaved, rocker studs, 10.3:1 compression Cam: Howards (roller) 233215-10 Lift .571/.577 Dur .269/.277 110 Lobe Center, 106 Intake Center Intake: Edelbrock 351F (told by Edelbrock not worth replacing with latest version). Carb: 750 Edelbrock vac secondaries Ignition: Recurved Duraspark II dist., Factory Duraspark (blue), 8.5 wires, Stock Motorcraft plugs .44 gap I did attach the 12V start bypass and ignition start retard to the solenoid. Exhaust: stock manifolds, Pipes cut off at mufflers (temporary) Compression #'s 174, 177, 175, 175, 174, 174, 175, 179 Vacuum: 15 psi relatively steady it was before but I had to add 1/2 a turn to each side to get it there again Plugs: Clean / reddish Oil and coolant are good Now that that's out of the way. 1. I'm thinking about disconnecting the spark retard wire from the solenoid. I read it was for easier starting but I'm thinking it's making worse with the compression and the heat. 2. Is 15 psi vacuum a good number for this cam? I was thinking 16-17 and that maybe there's a leak at the manifold? 3. The fuel pump is a mechanical replacement that has done more sitting than running in the four years it's been built. Weak diaphragm? I've been considering a regulator since these Edelbrock's are rather insistent on 5 1/2 psi. I'd appreciate any input. Thanks |
back story, how long did it sit with what in the tank? i like a see through filter between the metal fuel line off the frame and the fuel pump, 1 piece plastic not that 17 piece glass fire starter pos
lynchster
Everything is new including the fuel tank. Before installing the fuel tank I was using a 2 gal gas can in the trunk. It actually had one of those 17 piece glass fire starters on the front at the pump when I bought it. I'm not against another filter. It current has an inline at the front of the carb.
Edited by lynchster - 03-September-2022 at 8:04AM |
at this point i'd open the top of the carb and have a look in the bowl, see if it's collecting or growing anything. some carbs take a dislike to whatever's in the fuel and the finish on the alloy gets funky. take a peek
I'd wonder about the condition of the plugs and plug wires, the actual fuel pressure, and the coil wiring plus ballast resistor. Hopefully it's not about old gas or the affects of it. From curiosity, what duration is that cam also, the 0.050" specs? I like the smaller centerline figures, those sound good for a hot engine. Also what intake is on it exactly, what does 351F mean?
lynchster
Plugs and wires are new. Plugs looked good and double checked the gaps while they were out. Entire fuel system including the tank is new. I didn't use a ballast resistor I went with the factory resistor wire in the harness. |
lynchster
I actually got to talk with one of the people from Edelbrock that was trying to promote in house production of 4V heads and intakes. The actual intake is an F351. He pulled up a promotional flyer from 1972. It's an old version of their current dual plane intake. He suggested keeping this one the new one wasn't going to deliver much improvement.
On the hard starting when hot, be sure your starter cable from the solenoid is tucked alongside the oil pan rail and insulated. That was an issue I dealt with early on with mine.
78FordLtd2
Member Joined: 19-April-2021 Location: Canada Status: Offline Points: 160 |
It's either fuel or spark that's caysung your proplem. Take the top off the carb and see what's inside. Check your fuel pressure too. Also look at the routing of your fuel lines too. Could be vapor lock or fuel boiling out of the carb or in the line itself.
hogfiddles
Moderator Group Moderator Joined: 19-September-2016 Location: Central NY Status: Offline Points: 1511 |
My ‘76 had a ‘difficult to start, when warmed up good’ condition... that manifested itself as if the batter were almost dead— would barely turn over, and sometimes I’d have to wait an hour.
Turned out to be a starter issue.... got a new low profile starter and never had another issue
pyntre
Senior Member Joined: 29-March-2007 Location: United States Status: Offline Points: 206 |
I can’t offer you any more advice than has already been given but I would really love a video of the engine running when you get the problems ironed out !
I have that same roller cam picked out for our 400 build and would sure like to hear the idle sound on that !!!!!!! Does it move the car pretty well out of the gate ? |
this hard to start hot issue reminds of an Old Mechanic, he said "change the neg battery cable" he was right
lynchster
I have new ground cables with three ground points.
One starts at the clutch shield to the point in the frame where the battery ground cable attaches. I just ran another 4 guage wire from the front of the block to the terminal. Itvmaybe over kill but an electrician buddy of mine says you can never have too many. I did disconnect the white start timing retard wire from the solenoid. If it does the trick I may swap to a newer PGMR starter. I have to get this sputtering under control. It was after I put the gas in it from the station but I had 40 miles on it before it acted up the next day. I thought the dry gas and other gas might cure it. The 15 psi of vacuum is concerning but it did run well.
The 15 inches of vacuum isn't a big concern, the camshaft at 217/225 degrees isn't really that big at all. It sounds like the basic wiring is very good, and I'd concentrate on the fuel to and from the carburetor. Night,
lynchster
I know right? I was thinking it should be good for 16 - 17 psi but it's not my area of expertise. The overall results are about what I expected compared to the factory CJ cam. 👍 The issue is rather sudden. Maybe I need more than 4 gallons of new fuel and dry gas. Maybe there's an intake leak?
mkshelton
Was the rough running at idle or driving?
lynchster
I might have the hard start when warm fixed. Either the extra 4 guage ground wire or disconnecting the start retard feature seems to have done the trick.
The sputtering remains. Noticed it's mild when not fully warmed up but horrible fully warm. Could be bad gas? I do have a 1 inch spacer under the carb and those first runs were damn near flawless.
neg bat cable should go directly to the block, not any brackets or accessory mounts, OEM it went to the nearest motor mount bolt IIRC? then if you need to ground the body, back of the head to the firewall the frame is a poor ground base with all the body mounts, they're actually called isolators!
Negative cable on both my cars went to the block near the alternator then to the frame with the braided strap. Body from rear of right head.
qcode72
My carter afb 750 cmf,would stutter when cruising.Ifound the metering rods bent.I replaced with new Holley 1850. solved the problem. Car needed more than 5 gallon in tank. AV gas does not have same additives as non-ethanol pump gas.
lynchster
I think removing the white wire from the solenoid corrected the hard start when warm.
I've added a second bottle of dry gas (heet) to 8 gallons of gas (4 new). If the gas were any dryer the Torino would be requesting an olive. Still misfires bad at 3500 ish cold, 2500 warm but I do notice it at 1500. Tested the coil cold, hot, and against the coil I had in it before cold Original Primary. 1.8 ohms Secondary. 8.69 ohms Vertex Primary cold 1.0 ohms / hot 1.4 ohms Secondary cold 6.8 ohms / hot 7.16 ohms To me that seems to check out ok but I'm more of a mechanically inclined bodyman. I also put a vacuum gauge on it and it is steady over 20 hg over idle. Learning but I wish I were a better diagnostisian. |
lynchster
Not out of the question but I hope I didn't manage to bend mine after 80 miles.
the white wire ... i thought the red and white wire were for ignition power during crank and run? disconnecting either would cause hard starting or fail to run? is it possible you're running off the crank wire overheating the coil? |
lynchster
I'm using the factory pink resistor wire for the coil (no ballast).
The brown wire to the solenoid is to provide 12V to the start circuit. Operates at 8V? The white wire to the solenoid was to retard the timing at start to make it easier on the starter. Seem to make it too hard to turn over my engine when warm. I also read most people go with the red wire 12V and a ballast and don't bother with the white or brown wires at all. That's as best I recollect from researching before the conversion. After moving on from the coil I tested the vacuum advance canister to find it won't hold a vacuum. There's a vacuum leak! It's connected to the timed port. I disconnected it and blocked it with a vacuum gauge. The port works as it's designed but it didn't cure the misfire. A buddy offered up a distributor from a 460 to test with but I'm into learning diagnostics now |
white w/red stripe is 12v cranking iirc and red is keyed power... maybe the control module is failing???
lynchster
Possible too? I always thought the modules worked or didn't with no in between. Everything is new but I apparently have a bad cannister on the distributor regardless. Wire colors for the Duraspark might be subjective since I went with a Painless harness?
Edited by lynchster - 03-September-2022 at 11:01AM |
lynchster
Nice picture.
lynchster
To simply things a bit because I'm simple here is the wiring diagram I used for reference.
