429 SCJ -520 |
Dmarc28
Member Joined: 17-March-2018 Location: Garden Grove Status: Offline Points: 110 |
Posted: 28-August-2022 at 4:28PM |
Hey everyone heres ail update as to the progress on my engine.
I had a 429 SCJ built and was finally able to pick it up out in Colorado. Finally was able to put it on today. Here's some pics I'd the process. Hopefully they are the correct view. Now that its in i have some miscellaneous things that need to be done so Ii can drive it. Hoses, drive shaft, exhaust, shifter linkage . The shifter placement is off jus a bit. Need some advice on fixing that. Any and all suggestions are welcome. This view is looking straight down in the cab. Here's the specs. 603hp @ 5600 rpm 638 ft/lbs @ 4300 rpm |
What bellhousing kit is that? Do you have the hydraulic clutch setup?
what shifter do you have? the factory Ford / Hurst has an offset arm bracket. the round bar is 1972 and the flat bar is 1971 or 1973 i forget which ATM as does the aftermarket Hurst Competition Plus shifter |
Move/remove the shifter hump bracket.
fordpower
Senior Member Joined: 02-September-2010 Location: willseyville,ny Status: Offline Points: 1763 |
Is there any value in a seized 429
Depends on what seized.
fordpower
All it said is won,t turn over. It,s a 72 ranchero It's on the other side of Connecticut or new Hampshire .300mi to far to go look
Dmarc28
Its a lakewood 429/460 bellhousing. I am using mechanical clutch linkage.
Dmarc28
My 73 has the round shifter.
