Forum Home Forum Home > General Discussion > Video Gallery
  New Posts New Posts RSS Feed - Paint Revival & Rusted Roof Raptor Line
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Topic: Paint Revival & Rusted Roof Raptor Line
    Posted: 03-December-2022 at 5:48AM
Edited by Rockatansky - 04-December-2022 at 8:39AM
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2022 at 4:07AM
I watched that yesterday on Youtube, crazy!
Although in the end, he stopped the water from coming in and it has a nice texture look at 50'
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2022 at 8:40AM
i figured it's a good 'what to expect' when you peel back that crumbling Censored
he definitely needed to pull the front & back glass, repair the channels
car came from Vegas?
Edited by Rockatansky - 04-December-2022 at 8:45AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2022 at 7:28AM
at 1st i thought cheesedick bullCensored but this guy actually did a pretty fair job of it. sometimes you don't need / can't afford, justify or pull off by yourself a perfect duPont Registry level rust repair that nobody will ever see. i used fiberglass in my cowl job, i figure if the repair lasts longer than the rest of the shell i'm golden
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2024 at 11:49AM
Honestly, the roof repair was justifiable for this Elite. I see no reason not using Raptorliner to spray a roof instead of wrapping another top. It's more of a preservative effort instead of a full Resto. Main thing, cut the rot, patch it, and skim of fiberglass and block, and spray the Raptorliner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2024 at 3:09PM
Bed liner/rhino-liner/etc…… is becoming a big resto-mod technique for being a vinyl substitute/replacement.  I can attest that it’s tough…..it’s in the bed of my truck, and it get’s a good workout—and the bed is still rock-solid…….2006 Chevy LBZ
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2024 at 1:43AM
Just like paint using spray on bedliner to prevent rust and other issues, is very dependent on the prep work. Although the smoothness and filling of holes doesn't seriously impact appearance, it can trap moisture or allow moisture to creep under it causing the same issues as vinyl. I've seen a few trucks where poor prep work accelerated the demise of beds and rocker panels.
But, I have also seen a few cars with this as replacement for the vinyl top, and as long as the trim is in place it looked pretty darn good and you wouldn't realize until you got within 20 feet of the car.
I bet the care is a bit easier as well as any future repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 31-August-2024 at 5:31PM
Honestly, one of the big issues on any vehicle is stuff left to park outside. Moisture buildup on the insides of panels has been the root cause of so much body rot over the rears on roof structures.
Ultimately, if the panels are not cleaned of rust and properly treated and epoxied first and rust/corrosion removed, much like any body and paint work, it's doomed to fail.
