429 air cleaner |
1973gts
Senior Member Joined: 05-March-2018 Location: Grand Rapids Mi Status: Online Points: 608 |
Posted: 25-March-2023 at 1:46AM |
I am looking for a picture of a stock 1973 Torino 429 air cleaner set up. I want to have one for the stock look when going to car shows but haven't been able to find a pic on the web. thanks - dave
Dave - 1973 GTS N code
RacerJames
Member Joined: 25-April-2022 Location: 86401 Status: Offline Points: 50 |
Don't know if this is helpful, but I have an air cleaner from the '68 T-bird I drove in high school.
'73 Torino Stock Car
'71 Mustang Stock Car 351C powered |
I don't have a Torino pic, but here is one from a 1973 LTD, which I believe is the same for the most part. The 400 powered cars also used the same sized air cleaner. |
1973gts
Thanks Vince and James, those pics will help!
rcougarman
New Member Joined: 03-February-2010 Location: Missouri Status: Offline Points: 19 |
My first Torino had the 1973 429-4V. It looked like the 1972 version, but it had a Hemholtz resonator about 180 degrees opposite the snorkle. The resonator was made (literally!) from the same can used on FL-1 Motorcraft oil filters.
I had the great pleasure of working for a time in the early 2000's with the retired head of Ford powertrain and he confirmed that my thoughts were accurate about the filter housing being used. Not sure if they used this arrangement on anything other than the 73 model, but it might have shown up on 460's afterward. The resonator was to reduce engine air intake noise. Other than adding a tiny bit of weight it didn't reduce engine performance (or help it). Randy 72GTS now
1973gts
I've seen those in some pics, always wondered what their purpose was, thanks, Randy.
hogfiddles
Weren’t there ones that had an aluminum aircleaner cover, too?
RacerJames
If I remember correctly, the aluminum air cleaners started in '79 or 80 with the LTD body change.
