  New Posts New Posts RSS Feed - core support bushings
SEKCOBRA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Topic: core support bushings
    Posted: 06-July-2023 at 2:55AM
Anyone know what the best alternative to OEM Core support bushings are for a 72? Is there anyone out there that makes something close? I need the bushings and hardware.
Thanks
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
94 MUSTANG 5.0 LX NOTCH
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
64 Galaxie country sedan
1972 GTS Q CODE
1972 GTS Q CODE BLACK
Wayner315 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayner315 Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2023 at 3:09AM
I bought a boat trailer rubber roller and plan to cut it down to height. But there are universal ones that work. And also there's a good chat somewhere on the forum about body mount bushings where I think some guys talk about the core support options they went with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2023 at 3:32AM
Thats a idea. I have read alot of the discussions. Im looking for specific 72 style. I have read that 74 and up were different. Just thought maybe someone had gone through this and found a close plug and play option. Car is in the shop now and bodyshop is looking to start reassembly today. They are pretty good and can make something up but just thinking if i can save them time on fabrication it would help them and me. Lol. Shop ordered 08 CV bushings they think will be a close start or they can use some of the hardware to make them.
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2023 at 7:34AM
Thanks Wayner. Nobody else has any leads?? Not a problem I can make something from scratch just thought someone has been through this before. Thanks anyhow
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2023 at 11:44AM
We have lot of old threads on this, including this sticky:
Many have used # 9.4102R Energy Suspension Universal Mounts/Isolators (9.4102R).  You will see CJ's pics of them partway down the above post. They are also available in black as part #9.4102G.  I used the black ones on my '72 and they work with no mods required.  Of course depending on how many shims were used on your rad support you might need to make some minor tweaks.
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2023 at 2:55PM
I got the Crown Vic bushing set which included two different bushings that I used for the core support on my 73.  I combined them with the Ford stock shims to get to the stock height, they seem to be working fine.  I can't verify if the 72 core support mounts the same as 73, possibly another member has that info.
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2023 at 5:49AM
Ok thanks. I need everything. There was no hardware to try to duplicate. Thanks for the pictures and response.
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2023 at 12:54PM
Here are some pics of the Energy bushings that I used on my '72. I did have to trim the one bushing that sits on top of the frame, but other than that they worked perfectly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEKCOBRA Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2023 at 1:13PM
Thanks guys. This was a big help. Stopped by the shop today and they made some bushings from CV parts and it worked out perfectly. Thanks for the help.
69 Mach 1
70 TORINO COBRA
71 TORINO COBRA
72 Z28 CAMARO
72 GTS Q CODE
61 Galaxie 427
62 Galaxie 406
1972 GTS Q CODE
This page was generated in 0.146 seconds.
