  New Posts New Posts RSS Feed - 1972 GTS IVR part number
dreamzhappen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dreamzhappen Quote  Post ReplyReply Direct Link To This Post Topic: 1972 GTS IVR part number
    Posted: 26-July-2025 at 7:50AM
Hello;
I am ordering a new printed circuit board for my 1972 Gran Torino Sport. The printed circuit board does not come with the Instrument voltage regulator. When looking online I am getting mixed results for which IVR to buy. Does anyone know the correct IVR part number for my Torino? Any help would be greatly appreciated. This is a pic of my instrument cluster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2025 at 5:57AM
For the standard cluster it is:
D1AZ 10804-A
For the Rallye Cluster it is:
C9AZ 10804-A
This applies to all 1972-76 Torinos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2025 at 3:33PM
are those PN's not in the Cluster & Gauges info thread?
my recollection there are 2 IVR's, the terminals are opposite and mount different.
different for 77-79's? maybe, the printed circuits and lower housing are different.
leave it to Ford ....
Post Options Post Options   Thanks (0) Thanks(0)   Quote dreamzhappen Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2025 at 2:42AM
Thank you Vince! That was the one most places had listed so I ordered that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dreamzhappen Quote  Post ReplyReply Direct Link To This Post Posted: 29-July-2025 at 2:43AM
Looked all over the threads and could not find a part number for a 1972. Maybe I missed it, but I could only find for 1973 and up.
hotrodg57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodg57 Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2025 at 11:48AM
Guys, may I join in on this conversation? I purchased a 72 Ranchero Gt (with full gauges)  Problem is gas gauge did not work.  I have checked the sending unit (good) the gauge (good) so I replaced ivr. with the D1Az # Now, gauge works only when key is in Acc. mode, as soon as engine fires, the gauge goes off. So I checked the voltage at the gauge in Acc. mode (7volts) needs 6 . With key ignition on, voltage drops to (4 volts). Soooo then I see this post, and I realize I got the standard gauge part first time around, so I just installed new the C9AZ# and they don't work at all! This ivr is only putting out 5 and 4 volts!
Anybody have any Ideas? P.S. all other instruments work properly.
HELP
Rodger
72 Ranchero GT 351C 4V
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2025 at 6:42PM
HELP
Rodger
Maybe it's a defective repro IVR?  What kind of shape is the printed circuit in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodg57 Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2025 at 7:20AM
Vince, thanks for the reply. Printed circuit is brand new. This is the 2nd new ivr I tried. Both were repops. There is a NOS one on ebay right now, hmm??? I already have about 75 bucks invested in these things.
Do I dare try another one.????
 Just for the record , the turn signals weren't working either. I put a new flasher in, still no go. I tore the switch apart, all was good. Ouch, so I bought another new flasher, and it worked! Can these new repop parts be trusted?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodg57 Quote  Post ReplyReply Direct Link To This Post Posted: 10-August-2025 at 7:29AM
I bit the bullet, and just bought brand new ivr #3. This one is NOS, so I'm hoping I'll have better luck than with the last 2 repops. I will chime in when I get it here and installed. Thanks Rodger
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 11-August-2025 at 3:34PM
I am hoping that is your issue.  Please let us know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodg57 Quote  Post ReplyReply Direct Link To This Post Posted: 15-August-2025 at 12:39PM
Quick up-date, I just received the NOS part, I bench tested it, ant it actually works!Big smile
I will get it installed tomorrow and hopefully my darn gas gauge will work. Clap
I will let you knowConfused.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodg57 Quote  Post ReplyReply Direct Link To This Post Posted: 16-August-2025 at 8:06AM
Cry It don't workCry
Just installed new ivr#3, (it works on the bench, none of the others did), however once installed, nothingAngry just like all the others. I give up!  I'm buttoning this thing back together and it's going to be sold with no gas gageShocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodg57 Quote  Post ReplyReply Direct Link To This Post Posted: 25-August-2025 at 1:12PM
Ok guys, I apologize for my meltdown last week. I have calmed down.Clap
I did finely get my gas gauge working! IRV #3 was the NOS part that actually worked. P/N C9AZ 10804A.
I had to take a few days away.... Then went back and RE-TESTED my sending unit and now found it NOT working. Just put a new sending unit in, and what do ya know, everything works! Thanks for all the help and suggestions. Rodger
