9 inch rear tag info |
Regul8r
Posted: 04-August-2010 at 10:58AM |
pulled the tags off both 9 inch rear ends I have in the garage.
the 72 Montego tag reads
WEB-AD 2BD
2.75 9 812A
the 77 Ranchero GT500 tag reads
WEB-BH 7JB
2.50 9 810A
does this mean the Montego has a 2.75 ratio and the 77 Ranchero has a 2.50?
Were either of these limited slip or posi? Doubt it with those gears!!!
If I put the AOD in the Torino with the 77 rear end with 2.50 and big 275/60/15 on the back I would be at idle running the highway!!! Lean out the low end of the carb and get 20 PLUS MPG with that set up! But it will take a mile to get up to speed!lol
iangj
Senior Member Joined: 06-March-2009 Location: Fonthill, ON Status: Offline Points: 1019 |
Yes on your first question. To be LSD it would read2L75 & 2L50 respectively.
Ian Glyn-Jones
Fonthill, Ontario, Canada Wish I had My Baby Back Montego GT Registry Forum; http://mmgt.forumchitchat.com/ |
Regul8r
well that BLOWS!
these huge cars with all that weight and they have a stupidly high ratio!
Guess they needed that with the 3 speed trans of the day in order to run down the road at a fairly decent RPM while cruising.
you could build the AOD into a 4R70W and have a decent ratio off the line, and the advantage of OD down the road
E4OD planets work in a C6 the same way, but no OD
