oil pan |
fordpower
Posted: 30-August-2011 at 3:14PM |
what is the difference between a mustang 2 and a reg 302 oil pan.I want to lower my motor in the pinto but the sway bar is in the way.Told I need a mustang oil pan?
ghosttrain2
Member Joined: 05-July-2011 Location: Northern Nevada Status: Offline Points: 46 |
The difference will be whether it is a front sump, or rear sump.Mustang 2 and fox body Mustangs used a rear sump. 1973 and older were front sump.
1977 LTD, 2 door
1972 N code Ranchero, Project 1972 Torino formal roof 1970 Torino 500, Project 1974 Cougar parts car |
fordpower
would a mustang be smaller than reg. Mine is a front sump,large deep part in front.
75GranMan
fox body have double hump pan with two drain plugs.large in rear small in front,believe the pumps to be the same,but pickup are different.
fordpower
ya double was on full size also. Mine is just large in front. thanks for the input
bob |
mcford
mustang II is a front sump.
