Need help--Overheating after 5 miles!!!! |
79Cougar302
New Member Joined: 05-February-2007 Status: Offline Points: 10 |
Posted: 05-February-2007 at 4:25AM |
HI ---all I just got a 79 Cougar with 302.
It is also overheating after about 5 miles....I checked the radiator-- I got good flow.....it maybe low on oil......can't check it ......
Where is the engine oil dip stick location??????
I looked all over---I think it is possible missing.............. ....plus little water coming out of the muffler.......it could be a head gasket problem?????? Will that cause the over heating????
Thanks for your reply!!!! |
Psquare75
Some questions..
1. How do you know you have "good flow"?
2. Dipstick is in the timing cover, front of the distributor on a 302, IIRC.
3. A little water is normal on startup.
Dumb but necessary questions.
Radiator clear in front?
Does it overheat if sitting still?
79Cougar302
Thanks 75!
I don't know i have good flow ---the top on the radiator is getting hot water is what a meant.
Radiator is clear but I will double check....
Someone suggests it must be the thermostat...
Do you think it could be the problem??
It could I guess be very low on oil........I will search for the dipstick again........
Thanks in advance...........
Psquare75
It could very well be the thermostat.
When it's idling, from a cold start, feel the top hose.. it should start out cold, then all of a sudden become very warm.
You may even notice it on the temp gauge.. slowly increasing, until it hits a certain point... then it'll have a slight drop.. and stay steady.
