frame detailing, cleaning and pan what to do? |
Post Reply
| Author | |
kversch
Joined: 02-December-2009 Location: New york Status: Offline Points: 1399 |
Quote Reply
Topic: frame detailing, cleaning and pan what to do?Posted: 28-October-2011 at 12:31PM |
now that i have decided to do a frame off / frame swap with my 73, the next question i have for you guys is what is the best stuff out there to protect the frame once i have cleaned it all up and am ready to make it all nice and shiny again paint, powder coat ect?
what kinda paint should i go with. i know por 15 is good stuff but i am not a big fan of all the prep steps that it seems like you have to get just right or it wont work right and then you have to still top coat the por 15 to protect from uv light. Dan the ranchero man was telling me about a product he used that was similar to por 15 but i cant remember what it was so hopefully he will chime in on this. what have you guys used to redo your frame? also undercoating? any thoughts on this. My truck daily driver had good undercoating done to it at one point in time and i am very impressed at how well it has held up to the northern winters. most trucks of its age should have 1/8inch or thicker rust scale coming off the frame mine has very little scale at all. When the car is done it will be a driver / show car. im building it to enjoy, the threat of rain wont stop me from talking out for a drive. |
-kevin-
Brown 72 gran torino 351c 2v Black 73 GTS FB 302 Red 73 GTS FB 351C C6 trans 73 GTS FB Parted 73 torino 4dr, 302, FMX parted 97 F250 crew cab 7.3 diesel http://kverschtorino.blogspot.com/ |
lynchster
Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2150 |
Quote Reply
Posted: 28-October-2011 at 12:56PM |
I sandblasted everything the primered and painted it using automotive paint. The one concession I made was shooting the underside of the floor pans with single stage paint instead of basecoat / clearcoat. I would have loved to have been able to dip the frame to treat the insides but I don't plan on driving in the rain either.
ilyes
Joined: 09-January-2010 Location: Philadelphia PA Status: Offline Points: 3782 |
Quote Reply
Posted: 28-October-2011 at 1:33PM |
if you can, i would sandblast it, it will save lots of time and headaches
POR15 is really expensive, i would use something else |
CheeseSteakJim
Joined: 27-August-2010 Location: West Granby, CT Status: Offline Points: 82 |
Quote Reply
Posted: 28-October-2011 at 1:37PM |
How often will your frame be in direct UV light once it's under the body?
1972 Ford GTS Formal, H-code, automatic (SOLD)
1979 Chevy El Camino SS/Royal Knight, 355ci, TH350, Posi 10-bolt 1988 Lincoln Town Car, T5 5spd, 1966 Lincoln Continental Coupe 1981 Honda CB650 bobber |
legend onirot
METAL GOD Joined: 18-January-2009 Location: hattiesburg ms Status: Offline Points: 3038 |
Quote Reply
Posted: 28-October-2011 at 2:21PM |
thats the logic i used. i sandblasted mine, then painted it with por15. i then overcoated it with some clearcoat. the "clearcoat" had some uv protection in it. it wasnt very bad to do either.
kenneth
Joined: 19-May-2006 Location: New Zealand Status: Offline Points: 1373 |
Quote Reply
Posted: 28-October-2011 at 2:57PM |
I cleaned my old Torino (and long gone) 74 frame by hand, then had it acid dipped. The "cleaning it by hand" consisted of getting all the Mig/Tig welds nicely smoothed, adding my own welds to have less gaps, prior to the dipping, Then I POR15 her EVERYWHERE, then used a chassis wax to flow that inside the channels, I did my best without drilling any extra holes to flow the POR15 & wax inside.
Looking back on it and with unlimited funds available I would do the same but not use POR15 due to it being DANG hard to flow into tight confines, or at least pay someone who would spray it in/on. There is a flex air applicator but I don't think POR15 flows well throughout it. The powder coating I have had no experience with but getting it within the frame would be easier than anything else.
1973 Q code sports roof
75GranMan
Joined: 05-April-2011 Location: Colchester, CT Status: Offline Points: 1225 |
Quote Reply
Posted: 28-October-2011 at 3:08PM |
SEM makes a black primer that my body guy swears by. just ordered another quart of it today,to finish spraying my inner fenders an spot painting rad support and front portion of the frame.the finish is more of a satin black.very close to original finish of the frame.very durable can be use by itself with no topcoat.I don't have the # of it right now,but will get and post it with pix of parts painted with it.
iangj
Joined: 06-March-2009 Location: Fonthill, ON Status: Offline Points: 1032 |
Quote Reply
Posted: 29-October-2011 at 2:41AM |
Mine is going in for sandblasting Monday and then just down the street from there to be powder-coated.
I can't paint it for what I was quoted for powder-coating there. They come highly recommended around here. I'll takes pictures of everything as I have all along. One of these days I'll start a built topic on the MGT Resto.
Ian Glyn-Jones
Fonthill, Ontario, Canada Wish I had My Baby Back Montego GT Registry Forum; http://mmgt.forumchitchat.com/ |
mcford
Joined: 31-May-2003 Location: Utica, Michigan Status: Offline Points: 2174 |
Quote Reply
Posted: 29-October-2011 at 3:50AM |
Ian, i really wish you would! I'd like to see some pictures!
Guests
Guest
Quote Reply
Posted: 29-October-2011 at 7:38AM |
podercoat is the best way as it's basically bullet proof and won't chip.
powdercoat guy next to my old resto shop had a pipe with powdercoat as a sample and he beat on it with a hammer and everything else and it would dent but not chip off. It can be expensive depending where you live. Eastwood Company who sells stuff fro retoration purpose sells rust Encapsilating Primer and Chassis black and seems to be a reasonable way to go.A friend of mine used it on his 72 Buick GS frame and it came out nice.he just wire wheeled the frame with a drill or air die grinder and then after he cleaned the frame up sparayed it with the encapsolator primer and then follwed that with the chassis black paint rust encapsolator primer http://www.eastwood.com/rust-encapsulator.html regular chassis black -satin finish http://www.eastwood.com/ew-chassis-black-satin-quarts.html 2K Ceramic chassis black- satin finish http://www.eastwood.com/2k-ceramic-chassis-black-satin-quart.html they also have both chasis paints in gloss finish if you prefer a custom look but the satin is more OEM look |
Joined: 24-July-2011 Location: Mchenry,IL Status: Offline Points: 1185 |
Quote Reply
Posted: 29-October-2011 at 2:09PM |
iangj
Thanks(1)
Quote Reply
Posted: 29-October-2011 at 9:37PM |
Patience Grasshopper!
Ian Glyn-Jones
Psquare75
Member of the Stroker Club Joined: 26-November-2005 Location: United States Status: Offline Points: 4591 |
Quote Reply
Posted: 30-October-2011 at 1:55AM |
I too have changed from POR to Zero Rust. Usually for brackets and the back side of rust repair patches.
Quote Reply
Posted: 30-October-2011 at 7:51AM |
zero rust new website! http://www.amteco.com/products_zr_instructions.php
moose0211
Joined: 23-September-2009 Location: Baltimore Status: Offline Points: 456 |
Quote Reply
Posted: 30-October-2011 at 10:11AM |
I didn't do a frame off, but for my frame i used a wire brush to get all the loose stuff off, then painted it with "Mar-Hyde one step rust converter". My body guy recommended it and it seemed to do the trick. I'm planning on painting the floors and trunk with Zero Rust.
Eliteman76
Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 5450 |
Quote Reply
Posted: 30-October-2011 at 4:15PM |
I don't know Kevin. I used POR15 on my frame, and occasionally still to show people I will smack my frame with a ball peen hammer and it does not chip off as my frame was sand blasted with regular old sand I strained in a filter, and then I sort of just used a fork lift to position it.
This is a shot from 4 years ago: ![]() Stretching back a number of years, here was my frame after pulling the body: ![]() Stripped bare: ![]() Freshly blasted: ![]() I hung it off the forklift, and hosed it with the marine clean. Followed with a good long soaking in the metal ready. Followed this up with a couple throw away brushes, and a small foam roller. I brushed and rolled the frame out, and trust me, POR15 will flow into any crevice or opening. two thin coats. Held up great, and I have $100-$150 in POR15 at that time. Powder coating, if chipped, like any other coating, will fail and lead to rust. POR15 is no different. If I had it to do over again, I would have ground the frame, and welded and smoothed, and probably epoxied the hell out of it, but my car is a driver, and I am content with the POR15, 8-10 years later. |
Andrew:GTS.ORG admin, '72 Q code 5 speed RestomodPondering: #99Problems |
Psquare75
Quote Reply
Posted: 31-October-2011 at 2:08AM |
Unless you're making a trophy show car, or restoring something that has some monetary value, it better be a labor of love. I did a step less han Moose did. Wire brush what I could, liberally blasted undercoating all over everything. ![]() Did this first, before changing anything mechanical. ![]() After I painted the car... I ended up with this. ![]() White frame rails.. forgot to tape them off. Solution? ![]() More undercoat. The car doesn't see salt, but is sitting outside under a cover. I built it to drive, not sit at a Mercury Club of America show (Is there even such a thing? lol). |
picon3
Joined: 20-February-2007 Location: North Carolina Status: Offline Points: 2106 |
Quote Reply
Posted: 31-October-2011 at 2:26PM |
Kevin,
I went the frame off route. Had the frame sand blasted (literally) after everything was pulled off of it, then used DuPont 25xxS Epoxy DTM Primer-Sealer, followed by chassis black. It's held up relatively well, but the chassis black has a tendency to chip/peel off. The epoxy primer was white and has held up very well. If I had to do it again, I would use POR-15 (like I did on my 70 mustang) instead of chassis black; it's held up through seven years before I sold it last year. Paul~
1972 GTS 351CJ-4V black/black
Guests
Guest
Quote Reply
Posted: 01-November-2011 at 6:57AM |
well depending on your budget you have many choices from what everyone has listed.I know the eastwood primer and paint is very affordable the POR15 and powdercoat are probably the better of the choices as I can't say nothing for or against ZeroRust as I have never used it
Post Reply
| Tweet |
