Frame swap |
72MLC
New Member Joined: 10-December-2021 Location: Memphis Status: Offline Points: 39 |
Posted: 21-January-2023 at 3:46PM |
Hey gang! I have gone back and forth for a while now on if I wanted to frame swap with my donor car since it's immaculate. Mine isn't bad other than a front bumper mount bent but the other looks nicer. While not necessary (unless it being a power brake car versus mine not) what is the easiest way for me with a 2 car garage? Or is it better to attempt to find a place that may have better equipment to do so. Searched as usual, looked at youtubes etc and it looks like out of my skill set or I'm over thinking it (I am notorious at that) Thanks as always!
a few guys have lifted the body with 2 cherry pickers... ive done a couple with my HF overhead winch... but if its just the front frame horn id cut and graft a straight section on...
72 RS 351
Ditto, the frames are very stout and if it's just the front snout the bumper bolts to, that's not hard to fix. The only tricky thing is making sure that mounting surface is very close to the original. The bumper adjustment is all in the shims there, and movement possible up/down/left/right due to the hole slots.
72MLC
Thanks for the replies. Like I said, I tend to overthink. If I can ever find another front end, may even try and save the donor one day. Rotted roof due to the vinyl top but otherwise a running 35k original mile formal roof. The sportsroof is the one I'm bringing back to life.
Eliteman76
I would not recommend what I did what so ever. Death wish. Ah. To be young and really dumb...
Pondering: #99Problems |
hogfiddles
Moderator Group Moderator Joined: 19-September-2016 Location: Central NY Status: Offline Points: 1511 |
Looks plenty safe to me ……probably safer than how I did it— |
ahh!!! forgot that S hook on the cable!!!! when i lifted mine, it went up about a foot then the front started to tilt lowered it down, moved the sling ahead about 1" raised it and it tilted again lowered it down, moved the sling ahead another 1" still tilted lowered it and moved the sling strapping about 6" forward! still went up about a foot and tilted!!! looked under there and saw that S hook on the cable lowered it back down again and moved the sling back to the original balance point removed the hook and it worked flawless then
Anderslober
Senior Member Joined: 30-July-2019 Location: Denmark Status: Offline Points: 764 |
I was a big woos when the frame of my car needed repair. I caved and took the car to the pro’s. I was struggling with 2x4’s and straps….
i did mike's car the same way
Eliteman76
What's funny is on the Assembly Line pictures I have the cradle for our cars grabbed the roof rail, and the rear quarter panel wheel lip.
hogfiddles
Would love to see copies of that!
hogfiddles
Anders……it’s spelled “Wuss”—-
