  New Posts New Posts RSS Feed - Front End Alignment
Front End Alignment
piper62j View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Topic: Front End Alignment
    Posted: 12-January-2023 at 5:09AM
Has anyone done their own front end alignment without using a shop?  The mechanics where I live are only good with the later vehicles and don't know how and don't have the proper tools to align cars from the 60's and 70's.
Are there any DIY alignment tools you would recommend to do the job.. ?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 12-January-2023 at 7:14AM
Since I've lowered mine quite a bit, I had to elongate the upper A-arm adjustment slots to get proper camber. That said, I used a tape measure, string lines, jack stands(to attach string lines just past rear tires) and a 24" digital degree level. Can't check caster with any type of accuracy, but it was done over 13 years ago and the front set(s) of tires always wear evenly(I do rotate from time to time). Good luck and have some patience, for every adjustment you make changes more than one thing usually.
pyntre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2023 at 3:27AM
I would be interested in this too !
The prospect of dropping any of my classics off at ANY garage
keeps me awake at night !
Imagine doing an alignment on a 4 post lift would make it even an easier process as access to tie rods would be ideal .
If anyone else has success stories of do it yourself alignments
and the tools they used please add to this link !
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2023 at 10:20AM
I have never been around any alignment work done at home etc, but some companies do make some tools to help with some of it.
Maximum Motorsports makes something to help with caster etc, made for late SN95 Mustangs using their TRE kits that space the TRE lower due to mixing parts(SN95 spindle on a Fox Mustang). So there should be some specialty tools to help with an at home alignment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2023 at 11:55PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2023 at 11:49AM
I looked those caster tools up , seems they are for 77-79 era car . I wonder about that , how do you loosen the top control arm up and adjust stuff in fractional terms ? Just hit the control arm around till you get it where you want it ?! I like the idea of a threaded tool that would let you pull the arm fore and aft a few 1/6 “ at a time !
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2023 at 1:33PM
I bought these off EBay... It will make adjusting the caster and camber much easier.  All I need now is some sort of gauge that tells me what the angles are.. I'll keep looking.. there must be something out there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 19-January-2023 at 10:15AM
Which tool did you buy? The OTC tool above is supposed to be for 1979 and newer Panther cars. Not sure the will work on our Torinos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 19-January-2023 at 11:10AM
 when i had mine aligned he used a pair of those J hook tools but they didnt fit too good in the holes (could have been frame paint?) so he used a similar set for import cars??? hope these are the right? i grabbed them on ebay last night... snap-on...$40 couldnt go wrong i figured...?
https://www.ebay.com/itm/225033517693
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2023 at 9:43AM
These are the OTC 7091 adapters.. They didn't fit the holes in the frame, so I just opened them up with the next size up drill.  I'm looking into those bubble alignment magnets that are for sale all over the place.. I've got a book with all the alignment specs, just don't have all the tools.   YET!
This page was generated in 0.160 seconds.
