  New Posts New Posts RSS Feed - front seat rear stud
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: front seat rear stud
    Posted: 18-June-2023 at 11:54AM
Is it removable. I want to raise the bucket seats I installed. The rear stud is too short. before I destroy something is it removable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2023 at 12:49AM
Yes, they are removable, they unscrew from the threaded "U-clip" mounted in the floor pan gusset for the seats. May have to use two nuts to remove it. Once removed you can either use a longer threaded stud or a regular grade 8 bolt(which may be overkill, but...).Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2023 at 1:49AM
Thanks
This page was generated in 0.074 seconds.
