  New Posts New Posts RSS Feed - FRONT SWAY BAR
FRONT SWAY BAR
Scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott Quote  Post ReplyReply Direct Link To This Post Topic: FRONT SWAY BAR
    Posted: 07-August-2013 at 2:09AM
Does anyone have a good pic of there front stabilizer bar on their car? I need a good pic of 1 installed.Thanks,Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2013 at 11:54AM
Here are some quick shots that might help. Take care Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2013 at 5:27PM
not great pics of the sway bar... but I hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2013 at 1:21AM
Very good pics guys I really appreciate it.Dan looks like you have the heavy duty front bar on your car?That is what I am trying to put on mine it don't seam like it wants to line up right.Mine came from a 1973 GTS comp.handling pack car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2013 at 10:26AM
mine came off of a 72 GTS with the sport handling package. That has been installed on my 79 ranchero MX (ranchero with a 73 montego theme) and it bolted right up. What does not want to line up? Have you removed the lower control arms at one time and reinstalled them on the wrong side? could the bar be bent/damaged? Did the old bar fit correctly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2013 at 3:15PM
Okay I tried again and got mine on.Dan where did you get your bushings to go to the frame?I had to use old ones because nobody can come up with new ones that work in the u-bracket.O'reillys tried but they were wrong same as Carquest.Thanks again for pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 08-August-2013 at 3:44PM
I know you asked dan, but I replaced mine too.  I got mine from rockauto.com. I got all my bushings from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2013 at 2:35AM
Is yours the 1"7/8 bar from the 72-73  comp.handling package though or not can't tell from pics? I can't seam to get the right bushings for the bigger bar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2013 at 3:13AM
Buy the bushings by size, forget application.
Take a wrench and slide it over the bar.
Find the size that fits and order the bushing accordingly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2013 at 6:17AM
Energy suspension makes a TON of sway bar bushings and brackets. Here is a greasable set for a 1 1/8" bar (72-73 Comp bar) that would work. Most parts places can get energy suspension if you don't want to order online.
http://www.amazon.com/dp/B000CN5G40
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2013 at 6:51AM
i see what you are saying.  i think mine is the smaller one, but i thought rockauto had them both.  my bad
This page was generated in 0.181 seconds.
