  New Posts New Posts RSS Feed - fuse Box Heater slot
zjosh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zjosh Quote  Post ReplyReply Direct Link To This Post Topic: fuse Box Heater slot
    Posted: 06-January-2016 at 1:11PM
I have a 1974 Gran Torino. I pulled the dash wire harness out along with the fuse box. I notice there are not post for the box were it is labeled
heater it's a blank, anybody know why. I also have a 1975 Gran Torino, the fuse slots are different and it does have a slot with the fuse for the heater and has the fuse.
Any reason why the 74 does not have them and were the power for the heater comes from.
Also any ideas were I can get an AC connector for the 74. It's different from the 75.
Thanks Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2016 at 3:02PM
not sure, i'll have to look at my 74, i thought it had a fuse for the heater??? now you got me curious!
Post Options Post Options   Thanks (0) Thanks(0)   Quote zjosh Quote  Post ReplyReply Direct Link To This Post Posted: 07-January-2016 at 2:00AM
Thanks, it seems like it would have been a lot of work to take all the connections out and leave it black it there was an issue.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote zjosh Quote  Post ReplyReply Direct Link To This Post Posted: 08-January-2016 at 6:50AM
Any luck checking your fuse book out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-January-2016 at 10:50AM
check here in a few minutes
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-January-2016 at 6:17PM
ok, i looked at my 74 non-a/c fuse block... on the row opposite to the flashers, the upper slot is labeled heater, just below the two small slots that are labeled buzzer and warn lps. the next fuse slot below the heater is blank. if that helps? i think some are in different locations on some models??? the a/c cars may be a little different?
madmaxtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2016 at 8:20AM
74 is empty slot with fuseable link under hood by master cylinder on air cars.
Allan
Revelation 6:8
Post Options Post Options   Thanks (0) Thanks(0)   Quote zjosh Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2016 at 1:16PM
Thanks so much
This page was generated in 0.055 seconds.
