  New Posts New Posts RSS Feed - Gasket on engine plate?
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: Gasket on engine plate?
    Posted: 21-September-2022 at 2:44AM
Hi forum….the engine plate had a gasket on it. Is this normal?
Thanks.
78FordLtd2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 78FordLtd2 Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2022 at 2:49PM
If that is your timing chain cover, and it looks like it is, then yes, yhat seal is imporrant. It's your crank seal.
I've got to get on to swapping mine out soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2022 at 2:57PM
I don't think my Cleveland engines had any gasket material there around the rear crank seal area. It would be just to reduce dust etc, from reaching the rear main seal which would be bad for it. So it's not a bad idea to put a foam gasket there if it's made for that heat. There shouldn't be much air circulation back there to move any dirty air into the rear seal area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2022 at 8:41PM
It is not the timing chain cover. It is at the rear of engine….bell housing plate……rear engine plate…..whats the correct term?? No worries.
Is such a dust boot/gasket readily available somewhere?
The gasket on the plate is very brittle…it disintegrates to any touching.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2022 at 11:05AM
It is not critical at all, generally no Ford pushrod engines have that in any later years. Don't spend much time or money on it, either replace it with whatever you might find that can take 250* of heat, or forget it completely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 26-September-2022 at 1:19PM
I have only seen one in my Aamco days and  that was in 1984.
