Gran Torino Sport four speed install |
Post Reply | Page <1234 5> |
stuck
Senior Member Joined: 23-December-2007 Location: michigan Status: Offline Points: 279 |
im probably to late i prefer manual brakes and have a clutch pedal setup that may be power.
Edited by stuck - 17-February-2010 at 5:55PM |
michigan
ramair351
Senior Member Joined: 08-May-2006 Location: west michigan Status: Offline Points: 1561 |
ahhh. yup. oh well, they can be modified!
-Pete
1972 montego GT 1970 Torino cobra SCJ 1970 mustang mach 1 1965 Falcon futura |
ramair351
got a little done tonight, finally got up the nerve to cut the hole in the floor. no turning back now! actually i cut it out neatly with the saw pictured, so it could be put back someday if needed.
-Pete
Eliteman76
Not trying to sound like Mom, but make sure you treat the edge of the metal where you cut with some primer and paint. Bare steel= rust!
Pondering: #99Problems |
stuck
nice mine original looks like they used a dull air chisel
michigan
iangj
Senior Member Joined: 06-March-2009 Location: Fonthill, ON Status: Offline Points: 1019 |
Yeah they sure didn't take any care on the originals when cutting out the hole. All the ones I've had looked like they just blew through with a cutting torch or something. Very rough edges.
Buy your is so...... pretty!
Ian Glyn-Jones
Fonthill, Ontario, Canada Wish I had My Baby Back Montego GT Registry Forum; http://mmgt.forumchitchat.com/ |
picon3
Senior Member Joined: 20-February-2007 Location: North Carolina Status: Offline Points: 2097 |
1972 GTS 351CJ-4V black/black
ramair351
i attempted to stuff the pedal assy up under the dash tonight. what a pain in the ****. what with all the wiring, brackets trying to get in the way. this weekend I will try and get the trans installed. gotta spend time with the wife tomorrow, or else.
-Pete
Eliteman76
Pete...you would be far ahead to slowly remove the dash.
ramair351
oh i got it in there. it didnt suck as bad as removing the dash is!
-Pete
Eliteman76
Honestly, I've never considered a dash is that hard...pop off the steering wheel, leave all the hvac stuff alone, but loosen up the duct work, and unbolt the dash and just undo the connector at the firewall.
I guess I've taken one to many cars apart...
ramair351
i just hate disturbing the dash really, i already have a couple small cracks, they dont need to be any bigger
-Pete
ramair351
a little more done today. got the clutch installed. and the bellhousing. had to but a M/T starter, got one for $38. got a nice used clutch from Mcford. You can see the Z bar arrangement at the clutch fork. I cant do any more down here until i get some headers. maybe next week.
-Pete
Eliteman76
Pete...I ran into issues trying to source my starter, and of all things it ended up being a 88 bronco 5.8 efi 5 speed truck started.
Biggest thing I discovered-the length of the center stub for an automatic start will hit the bell house. |
ramair351
thats it exactly, the nose cone is short on a manual car. I just went to the parts plus website and looked one up for a manual trans v8 73 torino and BAM, it was correct, and its installed.
(dont tell them i gave them back a rusty core from my chevy boat motor)
-Pete
ramair351
-Pete
Eliteman76
Yeah, on the tube, I forget what size, but it's a heavy wall aluminized steel pipe. I forget my primary size, need to check dynomax's web site.
What ever they listed the 351c with a c4 on a 70's Torino.
On that one, biggest headache was around the collector and welding it up. Had to get creative.
I have one left over if you need it.
My think I did was cut the #4 tube off the flange to allow easier working on the car. I had my front clip off at the time, and sat on the tire as I cut, trim, cut trim, cut trim and made a pattern.
I had to shape it to clear the Z bar. It's a bit close to the PS box, but no issues.
I did have to dimple the #3 tube with a ball peen to clear, but that's par for the course.
Wish I was closer, I'd try to come over and lend a hand.
I can't take any pictures, as my car is still at my dad's.
ramair351
well, i butchered up a perfectly good set of headers today trying to make them work. they are past the point of no return today. i decided to run this header instead:
i am going to assemble the rest of the car with a pair of cast irons, and later i will use a set of Sanderson shortys that I found online, but they are $300 for a set. so we'll wait until next month.
Otherwise today i installed the transmission, shifter and made sure the parking brake was working and adjusted well.
-Pete
mcford
wonder if a set of tri-y headers would work?
ramair351
FPA has a set of Tri-ys, but they are closer to $500. ouch. i am going to the ford swap in columbus next month, armed with some measurements. maybe I'll get lucky
-Pete
mcford
yea, i am thinking a set of the old school shelby tri-y's may fit. hopefully someone will have a set there and you can measure them up.
ramair351
let the record show: today i tried some mustang 5.0 shorty headers, they will not work with a factory z-bar either.
-Pete
mcford
i think a budy of mien may have a set of try--y's. off the car. i'll check tomorrow.
72sport
Senior Member Joined: 22-October-2006 Location: Wisconsin Status: Offline Points: 614 |
Hey Ramair did the 5.0 shortys fit other than the zbar? I'm just thinking for the ltd II someday.
Tom
1972 Gran Torino Sport 4Spd 1974 Montego wagon "GT" with GT hood, correct buckets seats, console, and floor shift 2013 Focus 5 speed- Daily driver |
Eliteman76
Tom, I am pretty sure they don't.
With the 5.0 having a cable operated clutch, this isn't an issue.
72sport
The LTD II has an FMX so clutch issues aren't an issue for it. I'm just wondering if they clear the steering box. If I can ever put duals on it a cheap set of stock 5.0 headers would be a plus.
Tom
ramair351
the 5.0 mustang headers will work for an auto trans, i had them bolted on already.
-Pete
ramair351
NEWS FLASH!!
i have found headers that will work!!
these are sanderson headers part #FF3. they closely mimic the shape of a stock ford manifold. Being sanderson, they are expensive. retailing for almost $300. Ready for the best part?? I found a set of new ones on ebay, for the dart/roush cylinder head so they have the wide bolt pattern. buy it now only $88!!!!
these headers are sweet, and clear everything. best of all i can put the header bolts in lazily with a 3/8 air ratchet. plenty of clearance.
-Pete
ramair351
I also took the greasy steering gear box out and put in a input and output seal. heres a shot from underneath with the gearbox out.
here is the gearbox done, but not cleaned up and painted yet. also is the parts plus kit i got to reseal it
so, i am ready to finish the rough assemble. I will remove the headers and get them painted and baked before the exhaust is done. i need to get some angled reducers also.
-Pete
mcford
suh-weet!!!!!!
and i can confirm, 5.0 stang shorty's will work with an auto trans in the 72/up torino. my 72 chero had them.
