  New Posts New Posts RSS Feed - Help with front signal lights
JamieT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamieT Quote  Post ReplyReply Direct Link To This Post Topic: Help with front signal lights
    Posted: 23-December-2014 at 12:46PM
Does anyone know if the front signal lenses from a 78 T-Bird will fit a 78 Ranchero?
Jamie Thurber
68 Montego
78 Ranchero
US Navy retired
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2014 at 12:58PM
I am not sure if they will fit, but there is a 1979 ranchero being parted out. And those front signal lenses (from the 1979) should almost definetely fit. To see it Click Here.
image 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2014 at 1:01PM
There is also another 1979 ranchero being parted out. To see it Click here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2014 at 1:14PM
No, the thunderbird lenses definetely will not fit the ranchero. There is a picture below of a 78 ranchero.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2014 at 1:14PM
The T-bird lights won't fit "correctly in a Ranchero/LTD II front clip/header panel. The 77-79 Ranchero/LTD II turn signal lights/housings are getting very hard to find, with no aftermarket replacements available. If you find a Ranchero/LTD II in a wrecking yard get the things that have no aftermarket support, heck get all you can while you can. Good luck, Todd
Edited by aquartlow - 23-December-2014 at 1:15PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2014 at 1:15PM
I agree with aquartlow. There is a picture below of a 78 thunderbird. Notice how it has different lenses than the ranchero.
Edited by dave302 - 23-December-2014 at 1:21PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamieT Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2014 at 1:48PM
I can see the difference.  Those wider hideaway headlights forced the lights to be narrower.
I will be hitting the wrecking yards.
Thanks, Jamie
Jamie Thurber
68 Montego
78 Ranchero
US Navy retired
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2014 at 2:35PM
They are also taller
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2014 at 2:37PM
Originally posted by JamieT JamieT wrote:
Thanks
Your welcome.
