  New Posts New Posts RSS Feed - Hooker headers 6915hkr
AUS GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2021 at 5:50PM
Just to set the record straight for anyone looking at the 6915 HKR, I have just had them fitted to my 73 GTS Q code, t-bar & they fitted up great.
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2021 at 9:50AM
Do they tuck up under the body well and not hang too low below the floor pan? I'll probably buy those and also call them to ask if they'd coat them shortly after getting them. I'll replace the collector flange with a V-band flange, those seal better than the regular type.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2021 at 9:55AM
Yes being a 4 into 1 they do hang lower.... mine have about 4.5" clearance, but the car is lowered about 1.5".
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2021 at 10:22AM
Hey Don, hang on to your old 4v manifolds, apparently theres a market for them. You may be able to claw back some $.
Al
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2021 at 10:53AM
Yes, tough call some people make to go to LT or stick with stock manifolds. My 73 to sell has stock manifolds, I'm resisting a tear down and refresh. It's a mild build and I'd like it to have better intake, carb, headers, and cam etc. My keeper will be built from scratch with my original 351C engine, I let go of the stock 4V manifolds in about 1980.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2021 at 7:06PM
I just measured the ground clearance & its 3"..... soz fella we're more metrically inclined over here!
Al
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2021 at 10:04AM
Following....
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
This page was generated in 0.072 seconds.
