  New Posts New Posts RSS Feed - I thought I posted this!
 Post Reply Post Reply Page  <1 234
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2010 at 2:52AM
Yesterday I put on a set of OEM door edge guards I had from a car I parted. I also hit the local yard and grabbed a charcoal box setup from a 77 Cougar. I installed it and hooked it up as best I could (The Holley 4150 doesn't have a bowl vent you can attach a fuel bowl vent tube to). Amazingly, even with just the fuel tank vent plumbed into it, along with the air cleaner unit (like OEM), no more gas stink!. I'd stop at stop lights, go to accelerate on a green light, and get an eye watering rush of gas fumes in my face. No more! Cost? $16. Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2010 at 2:29AM
One big issue with this car is the steering is loose.. 160K miles and no real maintenance will do that I guess. The car came with a new steering center link, idler arm and pitman arm in boxes, as well as two ball lower ball joints. I ordered inner and outer tie rod ends and upper ball joints to finish it off.
I talked with the previous owner who said he replaced the shocks about 13 years ago, and used cheap Gabriels. He was on a budget and in a pinch. I looked around at what people were doing for larger cars, so I hit the Crown Vic forum. As much as I love the Bilsteins in my white Cougar, there's no way I'm spending $80 a shock on this car too. CV guys seemed to go between Bilsteins, Edelbrock IAS, and the Motorcraft replacement shock for 79-02 Crown Vic Police Interceptors. a 79-02 uses the same shocks as my Cougar :) (and all the 72-79 intermediates!)  Motorcrafts = $32 a piece.
Guess which way I went?
Should firm the car up a bit.
Turbo301 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2010 at 3:17AM
Nice, good to see Ford getting good mileage out of a part!
My steering's a bit loose, too; I thought it was just a function of it being a '70s car :). Can you post pictures of your suspension rebuild as you go? I'd like to see what's all involved in replacing bushings and the like.
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2010 at 3:49AM
I'm not doing bushings, this car already has polyurethane bushings all around. Just the steering components.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2010 at 2:49PM
Yay, suspension goodies. Yes I painted it all, totally overkill, but whatever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2010 at 3:22AM
Now with full length tailpipes
I need my daily driver back, I've been driving this thing daily for months, as much as I love it, I need to do some stuff to this car and it needs some down time :(
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2010 at 11:07AM
I thought it was the daily driver.
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2010 at 2:30PM
Nah, my daily driver is a Chevy Cavalier. This 11 MPG with 93 octane is getting expensive, every day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 30-May-2010 at 4:51PM
Wheel Swap... I got tired of seeing my Cragars and Nittos sitting...
So...
I'm thinking I LIKE this look, and I'm swapping the springs and wheels back to my white Cougar when the time comes, and calling it a day.
BTW TrucK/SUV Mudflaps will cover a 275mm wide tire. :)
So what did I put on my White Cougar?
Ermm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Posted: 30-May-2010 at 11:29PM
So...
Ermm
I dunno, I still really like th work you did on the stock wheels. EVERYBODY seems to do the Cragar 5-spoke look for their hot rods, it's nice to change that up! I still say do body-coloured inserts in the polycast rims, and that'd look slick :).
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2010 at 3:18AM
Meh. I only did the stockies because I had them and needed something, lol. My white car with the 523 spins the 17s all too easy, This car will now be a death trap with these MasterCrap, err, Craft, tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbo301 Quote  Post ReplyReply Direct Link To This Post Posted: 31-May-2010 at 5:39AM
That I can appreciate: that's a lot of power for those wheels, let alone the tires on said wheels!
Still, you did a nice job on the stock ones.
1977 Cougar XR7
1980 turbo Trans Am
2009 Pontiac G8 GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2010 at 3:43AM
Good Things.
With the Motorcraft shocks and 17" combo, the car handles AMAZING*. Firm but compliant. I LIKE these shocks.. I may sell my Bilsteins, as they are a little TOO stiff with the 17s.. but perfect with the 15s.
Bad Things.
Front wheels rub the fender edge on a turn BARELY at the rear lip.. Oh, and since the car is dropped in front, they rub the inner fender on top on a decent bump. ARGHHHHHHHHHHHHHH
Evil Smile
*For its size
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2010 at 3:05AM
A friend of mine does decals.
Smile
This page was generated in 0.112 seconds.
