Imjustrick from Lacey WA |
Imjustrick0904
New Member Joined: 28-November-2022 Location: Lacey WA Status: Offline Points: 16 |
Posted: 28-November-2022 at 10:16AM |
Thanks for letting me join the forum. I recently was given a 1972 Torino 2dr hardtop base model. It was originally a six cylinder car. But the previous owner installed a 289ci motor . And C4 transmission It is .030 over with a mild cam, GT40 intake, GM HEI conversion and Edelbrock 600cfm carb. The engine was rebuilt a verified 8k miles ago. The car came with the machine shop receipt and mileage at the time of the rebuild. There is 84,500 miles currently on the odometer. So far I've cleaned up the underhood wiring, deleted the column shift (removed both indicator and lever mount, filled holes and painted the column), installed a B&M Star Shifter, made new sail panels and package tray (with speaker cutouts), installed a 3" aftermarket tach in the clock bezel, fabricated a 3 guage pod in place of the factory seat belt light panel, nstalled a Bluetooth radio and 6x9 speakers under the package tray. All of the new electronics are wired with their own harnesses and plugs to disconnect for any changes or modifications.I still have an aluminum dual plane manifold, stainless steel headers and chrome valve covers to install . Still on my wish list are a 3:50ish rear gear and Tru trac, aftermarket rear trailing arms and wheels and tires. The body is fair with rust in the trunk and rear quarters. A couple small dents on the passenger side. Also have acquired some pieces to fabricate a useable grill that shouldn't look horrible. I'm working on that now and will post pics when I'm approved on the forum to do so. For now it runs and drives pretty amazing. It's definitely reliable enough to drive everyday if I want. I'm into the car for about $500 including tile and registration. Pretty good start to what is going to be my ongoing resto mod project. Lol .....I just started this project the second week of September.
Edited by Imjustrick0904 - 28-November-2022 at 2:34PM |
Wayner315
Senior Member Joined: 19-October-2021 Location: Alberta Status: Offline Points: 215 |
Decent list of work. Look forward to pictures once you have such privilege's. Welcome
cool! im about 45 mins away... welcome!!!
Senior Member Joined: 08-June-2019 Location: Florida Status: Offline Points: 1756 |
Welcome.
Imjustrick0904
North south east or west?
Edited by Imjustrick0904 - 28-November-2022 at 2:35PM |
67gt5003119
Senior Member Joined: 09-December-2012 Location: Gig Harbor Wa. Status: Offline Points: 513 |
Welcome from Gig harbor!!
Welcome to the forum! I have upgraded you to a full member so you have full forum privileges and can post pics. Sounds like you have a nice Torino. Post some pics when you can.
south in winlock
Imjustrick0904
i just saw and approved your post about trunk weatherstrip... are you needing the metal or the rubber seal?
Imjustrick0904
A few of my interior projects and stuff that will have to do for now 😁
Imjustrick0904
I need all the way across the top and top right hand corner, most of the way across the bottom and both bottom corners. It's a real mess.
i'll check i may have part of that...?
Imjustrick0904
That's awesome.......thank you.
Imjustrick0904
Lol.......do you by chance have panels to repair both quarters behind the rear wheel opening from the lower body line down? Asking for a friend 😁
not that are any good left, i think i have a 74 drivers quarter, i do have a nice pair of 72 fenders
